Default Displacement Overview
This section allows you to control the displacement quality for all objects in the scene. These options are overridden for objects which have the additional displacement settings added through VRayDisplacementProperty.
Default Displacement Parameters
Tight bounds - when this is on, V-Ray will try to compute the exact bounding volume of the displaced triangles from the original mesh. This requires pre-sampling of the displacement texture, but the rendering will be faster, if the texture has large black or white areas. However, if the displacement texture is slow to evaluate and varies a lot between full black and white, if may be faster to turn this option off. When it is off, V-Ray will assume worst-case bounding volumes, and will not presample the texture.
Amount - this is a scaling parameter for the default displacement. Values larger than 1.0 increase the displacement amount, while values lower than 1.0 reduce it
View-dependent - when this is on, Edge length determines the maximum length of a subtriangle edge, in pixels. A value of 1.0 means that the longest edge of each subtriangle will be about one pixel long when projected on the screen. When View-dependent is off, Edge length is the maximum subtriangle edge length in world units.
Edge length - this determines the quality of the displacement. Each triangle of the original mesh is subdivided into a number of susbtriangles. More subtriangles means more detail in the displacement, slower rendering times and more RAM usage. Less subtriangles mean less detail, faster rendering and less RAM. The meaning of Edge length depends on the View-dependent parameter above.
Relative to bbox - if this parameter is on, the actual displacement amount is based on the bounding box of the objects. If this option is off, the displacement is expressed in generic world units where white areas in the displacement map correspond to displacement of 1 generic unit. You can use the Amount parameter to increase or decrease displacement amount.
Max subdivs - this controls the maximum subtriangles generated from any triangle of the original mesh. The value is in fact the square root of the maximum number of subtriangles. For example, a value of 256 means that at most 256 x 256 = 65536 subtriangles will be generated for any given original triangle. It is not a good idea to keep this value very high. If you need to use higher values, it will be better to tesselate the original mesh itself into smaller triangles instead.
