Irradiance Map Viewer Overview
The irradiance map viewer can be used to view, merge and save irradiance map files created by V-Ray. Note that the viewer is a separate program and does not require Maya in order to run.
Usage
There are several methods of running the irradiance map viewer, which are outlined below.
  • The simplest way is to double-click the imapviewer.exe file from the V-Ray Standalone distribution that ships with your copy of V-Ray for Softimage. This will bring up an Open File dialog box that lets you browse for an irradiance map to open. This is the same as starting the irradiance map viewer from the Start Menu. The menus of the program allow you to do various things with the irradiance map (merging and saving etc).
  • You can also run the irradiance map viewer from the command line. In this case there are several possible choices:
    • If you type just
      > imapviewer
      on the command line, this is the same as double-clicking the file. It will bring up the File Open dialog for selecting an irradiance map file.
    • You can also type
      > imapviewer <filename>
      where <filename> is the name of an irradiance map file. This file will be opened automatically.
    • A third way is to use the viewer to merge several maps into one:
      > imapviewer -load <map1> -load <map2> ... [-save<finalmap>] [-nodisplay]
      This will load the specified maps and combine them into one irradiance map. If the -save option is specified, the result will be written to the given file. If the -nodisplay option is specified, the resulting map will not be displayed (otherwise the viewer will display the final result).
  • Use the "-help" option on the command line to see a short description of the usage of the irradiance map viewer;
