Register V-Ray License Service
The V-Ray license server can be registered as a Windows service in order to automatically run on the Windows boot. To do that go to Windows Start > All Programs > Chaos Group > V-Ray License Server for x64 > Register V-Ray License Service
To remove the V-Ray license server from the list of Windows services go to Windows Start > All Programs > Chaos Group > V-Ray License Server for x64 > Remove V-Ray License Service.
V-Ray License Settings Change
If you are running the V-Ray license server on a different machine, you need to tell V-Ray for Softimage where to look for it. This section describes how to do that.
Run the V-Ray license client configuration utility setvrlservice.exe that came with the V-Ray for Softimage installation archive
This will show you the window below, where you can specify the IP address of the machine that is running the V-Ray License Server. Please do not change the connection port that is set by default to 30304.
For example, if the license server machine has IP address of 10.0.0.100, you have to put that address in the “License server” field, under the tab “Primary license server”.
