This page provides information on the V-Ray Bercon Tile Texture.
The V-Ray Bercon Tile Texture map can be used to generate a procedural tile texture. It can use custom colors or texture maps, and provides a number of style types. This texture can be used as an input to many different material channels to produce varied and complex effects.
Main
Colors
Tile – Specifies the tile color.
Gap – Specifies the gap color.
Lock to Gap Color – When enabled, locks Edge color to gap.
Edge – Specifies the color of the edges between the tiles. This could be thought of as mortar between the tiles.
Distortion
Use Distortion – When a texture map is connected to this channel, it distorts the V-Ray Bercon Tile texture depending on the texture map.
Distortion Strength – Solid colors have no effect and the more contrast in the connected texture, the more visible the distortion.
Tiles
Tiling
Pattern – Gives access to a number of preset patterns for the V-Ray Bercon Tile procedural texture. The available options are Custom (uses parameters specified in the Custom Bond Pattern below), Herringbone, Stack Bond, Stretcher Bond, Flemish Stretcher Bond, Common Bond, Flemish Bond, Monk Bond, Flemish Garden Wall Bond, English Bond, English Cross Bond, Double English Cross Bond.
Size – Specifies the size of the procedural texture.
Tile Width – Specifies the width of the tiles.
Tile Height – Specifies the height of the tiles.
Edge Width – Specifies the width of the Edge color. Larger values give a wider mortar.
Edge Height – Specifies the height of the Edge color.
Soften – Specifies the selection of the different types of softening. This channel can be either set to a value of None, Linear, Round, or Smooth.
Soften Radius – Specifies the radius of the selected soften type.
Round Corners – When enabled, all corners are rounded by the value in the Round Radius channel.
Round Radius – Specifies the circular radius when the Round Corners parameter is enabled. This setting interacts depending on the type of the Round Corners parameter.
Custom Bond Pattern
Pattern – Allows the creation of custom tile patterns using inputs for offset, height, width1, width2, or offset, height, width1. A Negative offset is multiplied by a row number. For example, a pattern of -0.5,0.5,5,2 produces a wooden flooring effect, and a pattern of -0.25,0.5,1,0.5 produces a decorative diagonal brick pattern. However, if just offset, height, and width are input as -0.3,1,1, a more traditional brickwork/tile pattern can be created. All user created patterns can be saved as a custom preset.
Tile UV
Enable Tile Mapping – When on, enables tile mapping.
Channel – Specifies the UV channel when Enable Tile Mapping is on.
Auto Scaling – Specifies the auto scaling from None, UV, UV Fit, UV Fit Keep Aspect, UV Normalized, and UV Normalized Keep Aspect.
Random Offset X – Randomly offsets the x-axis.
Random Offset Y – Randomly offsets the y-axis.
Random Size X – Applies a random size to the x-axis.
Random Size Y – Applies a random size to the y-axis.
Lock X/Y Sizes – When enabled, random Y size is the same as X size.
Random Rotation – Specifies the random rotation method from None, 90 Degrees, 180 Degrees and Random°.
Degrees – Specifies a random rotation angle when the Random Rotation option is set to Random°.
Random Flip X – Randomly flips the x-axis.
Random Flip Y – Randomly flips the y-axis.
Enable Center Mapping – When on, enables center mapping.
Channel – Specifies the UV channel when Enable Center Mapping is on.
Randomize TexMulti – When on, enables randomization of V-Ray Multi ID texture.
Output
Camera Space – Enables calculations in camera space.
Color Tweaks
Default Color – Specifies the color when there are no valid UVW coordinates.
Mult – Specifies a multiplier for the texture color.
Offset – Color corrects the texture by adding the RGB color values specified here to the RGB color values in the texture.
Invert – When enabled, the resulting texture color is inverted.
Alpha Tweaks
Source – Specifies the alpha source from Alpha, Color, and Opaque.
Use – Differentiates between textures exported from different applications. You can choose between Color Intensity (3ds Max) and Color Luminance (Maya).
Mult – Specifies a multiplier for the texture alpha.
Offset – Specifies an additional offset for the texture alpha.
Invert – When enabled, the resulting texture alpha is inverted, too. If disabled, just the color is inverted.
Placement
Placement Type – Specifies the way the valid portion of the texture is applied. The options are Full, Crop, and Place.
U/V – Specifies the U/V coordinates of the valid texture sector.
W – Specifies the width of the valid texture sector.
H – Specifies the height of the valid texture sector.
Jitter – Specifies the amount of random placement variation.
Tile U – When enabled, there is horizontal tiling.
Tile V – When enabled, there is vertical tiling.
UV Noise
Enabled – Enables the UV noise.
Amount – Specifies the UV noise amount.
Levels – Specifies the UV noise iterations.
Size – Specifies the UV noise size.
Animated – When enabled, the noise is animated.
Phase – Specifies the UV noise phase.
Mapping
Type – Specifies the mapping type.
UV Name – The name of the UV channel that is used.
Repeat U – Multiplier for U values.
Repeat V – Multiplier for V values.
Coverage U – U values are remapped to 1.0.
Coverage V – V values are remapped to 1.0.
Translate Frame U – Translates the frame in U direction after applying rotate_frame (and before wrap, coverage, clamp).
Translate Frame V – Translates the frame in V direction after applying rotate_frame (and before wrap, coverage, clamp).
Rotate Frame – Rotates the frame after applying UV noise.
Rotate UV – Rotates the UVs after mirroring.
Offset U – Offset added to U before mirroring (after wrap, coverage, clamp).
Offset V – Offset added to V before mirroring (after wrap, coverage, clamp).
Noise U – Noise magnitude multiplier in U direction.
Nose V – Noise magnitude multiplier in V direction.
Mirror U – When enabled, every other tile outside the [0;1] range is mirrored in U.
Mirror V – When enabled, every other tile outside the [0;1] range is mirrored in V.
Wrap U – When enabled, U values outside the [0;1] range wrap back to [0;1].
Wrap V – When enabled, V values outside the [0;1] range wrap back to [0;1].
Stagger – When enabled, tiles in the V direction add +0.5 to the U value for a 'staggering' effect.
Type – Specifies the type of projection mapping to use from the following:None
Planar
Spherical
Cylindrical
Ball
Cubic
Tri-Planar
Perspective
Projection Camera – Selects a camera.
Projection Camera (LOP) – Same as Projection Camera parameter but for use in the LOP context.
Fit Fill – Specifies how the projection is fitted.
Fit Fill – Fitted to fill the space.
Horizontal – Fitted horizontally.
Vertical – Fitted vertically.
Fit Type – Specifies the type of fitting to use:
None
Match Camera Film Gate
Match Camera Resolution
U / V Angle – Specifies the U / V mapping angle.
Film Gate W / H – Specifies the width / height of the film gate.
Hide Backface – Determines whether to project on back faces of polygons.
Hide Occluded – Determines whether to project on occluded points when using the Perspective Type.
Object Space – When enabled, the projection is applied in the object space of the currently shaded geometry.
Use Reference Points – Uses reference mesh/rest inputs for projection calculations.
Mapping Type – Specifies the type and shape of the texture from the following: Spherical, Angular, Cubic, Mirror Ball, Screen, Spherical (3ds Max), Cylindrical (3ds Max), Shrink Wrap (3ds Max), and Spherical (V-Ray).
Horizontal Flip – Flips the environment horizontally.
Vertical Flip – Flips the environment vertically.
Horizontal Rotation – Specifies the horizontal rotation (left and right).
Vertical Rotation – Specifies the vertical rotation (up and down).
Texture Rotation – Specifies the texture rotation.
Wrap U – If true, U values outside the [0;1] range wrap back to [0;1]. You can choose between the No Wrapping, Wrap and Mirror Tile options.
Wrap V – If true, V values outside the [0;1] range wrap back to [0;1]. You can choose between the No Wrapping, Wrap and Mirror Tile options.
Wrap X – If true, X values outside the [0;1] range wrap back to [0;1]. You can choose between the No Wrapping, Wrap and Mirror Tile options.
Crop U / V / W – Enables or disables cropping in the U / V / W direction.
DUVW Scale – Specifies an additional scale factor for the texture derivatives.
Ground – Enables ground projection of the texture.
Ground Radius – When Ground is enabled, this specifies the radius of the ground.
Ground Position – When Ground is enabled, this specifies the coordinates for the ground.
