This page contains information about the V-Ray TexCombineColor node.
The V-Ray Combine Color texture blends together a texture and a color.
Texture – Specifies a texture that is combined with the color.
Custom Color – Specifies a custom color.
Texture / Color Blend – Specifies a texture multiplier that is used to blend between the color and texture.
Result Multiplier – Specifies a multiplier for the result. If Invert Result is enabled, this is performed after the inversion.
Invert Result – When enabled, inverts the result of the blending effect.
