This page contains information about the V-Ray Edges Texture.
Example: Show Hidden Edges parameter
disabled
enabled
Example: Consider Same Object Only parameter
In this example, the cube and the cylinders are separate objects in the scene. V-Ray Edges is used as a bump map on all objects.
When the Consider same object only is enabled the rounded corners effect is applied to each object individually. When the Consider same object only option is disabled the rounded corners effect is applied between the different objects.
disabled
enabled
Example: Mode parameter
Convex and Concave corners
Convex corners only
Concave corners only
