© Taichi Kobayashi
Official Release
Date – 15 October, 2020
Download – Build 4.30.03
Download
New features
VRScene
  • Enabled VRScene export from Houdini Indie
  • Added support for unpacking the VRScene into live polygon geometry under the "Import" tab of the VRScene SOP
VRProxy
  • Added support for render-time baking of subdivision and displacement into a VRMesh from the V-Ray Object Properties "Bake Geometry" tab
Hair
  • Added "ACEScg" color space support for the Hair material
UI
  • Аdded a "Reset VFB Position" button under the Images tab of the Renderer ROP
  • Updated the File Browser type for image paths
Houdini
  • Changed the Console / Log window behavior - the V-Ray Log window is now always used instead of the native Houdini console
  • Added support for Houdini 18.0.499
  • Added a Pack Scene option under the V-Ray Main menu
  • Added a V-Ray Renderer TOP node
  • Added support for the "Representative Node" option on HDAs
  • Added an "About" button to the V-Ray menu that shows detailed V-Ray for Houdini and V-Ray Core information
  • Added support for Houdini 18.0.566
  • Added initial support for Houdini 18.5
  • Added support for textures embedded in HDAs (currently limited to PNG image file format)
  • Updated the V-Ray main menu with buttons linking to the documentation, forum and tutorials section
  • Added support for HDA embedded textures in JPG, PNG and TGA format
Textures
  • Added a Random texture that accepts either a float or vector value as a seed to generate either a random float or a random vector value
  • Added the Volume Grid Texture used for sampling voxel values from a volume
  • Added a custom Pattern ID texture that can be used with the Multi ID Material/Texture for assignments based on string attributes placed over packed primitives or packed alembic primitives (Note: this will not work with string attributes placed on the individual faces of polygon mesh)
  • Added the GLSL Texture VOP
Texture Baking
  • Added Post-Translate Scripts support to the V-Ray Baker Tool
  • Added the Denoiser render element to the V-Ray Baker Tool
Deadline ROP
  • Added custom Environment Variables export parameter to the Deadline ROP
Rendering
  • Added an initial integration of the Volume Grid Texture for sampling voxel data
Lights
  • Added light linking support for the Volume Scatter material
Materials
  • Added the GLSL Material VOP
Export
  • Added support for multiple Post-Translate scripts
  • Added support for the Transform VOP
Hydra/Solaris
  • Added initial Solaris support accessible through the "V-Ray (Alpha)" option in /stage
Modified features
Alembic
  • Added support for displacement over an Alembic file with a baked "shop_materialpath" attribute
  • Added support for the "alembicfullvisiblity" intrinsic attribute
  • Added support for the Hair Properties' "Tessellation Multiplier" and "Geom Splines" options for hairs contained in a Delayed-Load alembic
Rendering
  • Material assignments are lost for instances using @instance or @instancepath when Rayserver Instancer is enabled
  • Sped up Rayserver Instancer when rendering single-level hierarchies of instances
  • Added “Estimated Time Remaining” support for the V-Ray Frame Buffer
  • Added a "Save Deep Data to Separate Files" toggle under the Images -> Advanced tab of the Renderer ROP
  • Added a "Save Color Corrections to Raw Files" toggle under the Images -> Advanced tab of the Renderer ROP
Installer
  • Updated the json environment setup due to a QT libraries conflict causing the Houdini Help Browser to stop working
  • V-Ray for Houdini builds are now always installed in the default HFS path for the selected V-Ray version
Textures
  • Added a Color parameter to the OCIO Texture
  • Added "Horizontal Rotation" and "Vertical Rotation" parameters to the UV Environment VOP
  • Added missing "Extrapolate Type" parameter to the Bezier Curve texture
  • Exposed the "Cache Size" option under the Renderer->Options->Textures tab used for limiting the amount of RAM consumed by textures
  • Added a "Clamp" option to the Bezier Curve texture
  • The Volume Grid texture now expects a disk file path instead of a node path
  • Added support for the $F tag in the texture path for lights
VRScans
  • Removed the Color Space parameter from the VRScans material - this is automatically handled by the Color Space parameter on the Renderer
  • Sped up the preview when loading VRScenes containing V-Ray Proxies
  • Updated preview for meshes with a large numbers of faces
AOVs
  • Restored the "Zero Infinity Depth" toggle to force a black background color for the Z-Depth element
  • Added support for the Cryptomatte "User Attribute" mode when rendering with the GPU
Volume Grid
  • Removed the "*.vdb" file extension filter from the Volume Grid Cache SOP's File Browser dialog
Texture Baking
  • Added the option to explicitly specify the UDIMs to bake in the V-Ray Baker Tool SOP
  • Disabled the export of splines and particles when baking textures with the V-Ray Baker Tool SOP
  • Automatically recalculate invalid normals on Mesh export to resolve empty AOV output for geometry with (0, 0, 0) normals
  • The "Consider for AA" toggle for render elements is now exposed on the V-Ray Baker Tool
UI
  • Removed the "Use Particle Color" parameter on BSDF Point Particle material because it's redundant with the User Color VOP available
  • Restored UI visibility of the “Translate” parameter on the Dome Light due to a forum request
Deadline ROP
  • Added support for per-frame VRScene export and Deadline Task per VRScene submission
Export
  • The OpenSubdiv toggle on the V-Ray Object Properties will now work for Alembic Delayed Load primitives
  • Added support for float attributes on vertices
  • Added support for the V-Ray Sampler RenderID parameter for render-time randomization of VRScenes
  • Added support for instanced lights with animated visibility
  • Added support for the V-Ray Hair Properties when rendering Alembic files containing hair primitives
Volume
  • int 'vray_objectID' point attribute can now be added to packed volumes for use with the ObjectID or Multimatte render elements
Lights
  • Added support for automatic generation of multiple mesh lights from packed geometry coming through a single Geo node
Materials
  • Added the Anisotropy UVWGen input to the V-Ray Material
  • Updated the V-Ray Toon material to the latest version available in V-Ray Core
GPU
  • Added support for more than 10 materials in MtlMulti when rendering with V-Ray GPU
VFB
  • Added a "Remaining Time" progress bar to the V-Ray Frame Buffer
Hython
  • Added a wrapper for the ropNode.render() method to resolve syncing issues when rendering in a loop through hython
Houdini
  • Creating a V-Ray Renderer will now always create a V-Ray IPR ROP as well
Bug fixes
Alembic
  • Empty render when the Geometry node holding the Alembic file is inside a Forced Matte Subnet node
  • Fixed a hang on render start with particular Alembic file and Displacement enabled
  • Crash when rendering a particular Alembic file containing degenerate faces
  • Baked s@shop_materialpath assignments are lost when enabling Displacement from the Object Properties of the parent node
AOVs
  • Forced material assignments from an Alembic baked shop_materialpath would not be registered for Cryptomatte in "Material Name" mode
  • BRDFs hooked up to a Blend material had wrong output for the Material Select element
  • Updated Cryptomatte VOP UI
  • Fixed a crash when selecting a Bump BRDF VOP into the Material Select Render Element
  • Fixed a bug with the Object Select AOV causing the Physical Camera's "Exposure" parameter to be ignored for the AOV output
  • The "Don't Save RGB Channel" toggle did not work as expected
  • Crash when selecting Bump VOP into Material Select render element
GPU
  • Fixed a crash when opening a new scene after rendering with GPU
  • Hang after rendering a volumetric on the GPU and trying to close Houdini or open new file
  • Fixed a crash with a specific scene when rendering on the GPU
Deadline ROP
  • Export a single Houdini job with sub-tasks when the Mode is set to "Render Job"
  • Fixed a bug causing "Director" to be used in place of the ROP node name when "${OS}" is part of the export path
  • Selecting slaves for the Machine List adds a "Qt: Untested Windows version 10.0 detected!" message to the list
  • Default Deadline ROP Frame Range for "Frames per Job" export was one frame shorter than the entire timeline range
  • Added support for UNC paths
  • Fixed a bug causing wrong evaluation of the "${OS}" variable for the Image and VRScene output paths
  • Environment texture parameters are not exported when no input node is provided to the slot causing V-Ray to use the "background" texture
  • Fixed a bug causing wrong output on the farm when Deep Output is enabled on the Renderer ROP
IPR
  • IPR is not updated for volumes when the Renderer's Sampler type is set to "Bucket"
  • Hooking/unhooking nodes under a File SOP used to load VDBs (e.g. Transform SOP) did not update IPR
  • Changing the visibility flag on a piece of geometry would occasionally cause the entire geometry to disappear
  • Creating a node inside a V-Ray Material Builder VOP used to restart the IPR even if that node is not a part of the shading network attached to the rendered geometry
  • Adding or removing an input connection to a VOP node would occasionally fail to update IPR
  • Pressing the "X" button on the VFB to close the window would not stop the IPR
  • When Motion Blur is enabled, objects with velocity blur used to have wrong motion blur after changing the Timeline frame
  • V-Ray Clipper was not updated in IPR
  • In some cases instanced geometry would not update in IPR
  • Adding or removing an input connect to a VOP node does not update IPR
  • Fixed multiple issues with IPR inside the Houdini Render View window
  • Distance texture was not rendered in IPR
  • Moving the camera during IPR causes "Camera Motion Blur" to disappear
  • The position of an animated camera was not updated when changing the timeline frame during an IPR session
  • Starting IPR with no Camera present in the scene does not bring up the VFB to the foreground
  • When IPR is started in the VFB without a camera, the VFB window would disappear
  • Volume Grid Shader ramps are not updated in IPR
Export
  • Geometry with no animation keyframes disappears when using Rayserver Instancer with Motion Blur enabled
  • Added required metadata for Material Select element to support sub-BRDFs selection when e.g. Blend material is assigned
  • Wrong animation frame keys exported when using Time Shift to lock the time for an Alembic file containing multiple samples to the current frame
  • The "Find Sun Automatically" toggle on the V-Ray Sky texture was not working
  • Fixed a crash caused by forced Vertex attribute export
  • Forced subnet with forced children produces multiple visible nodes
  • Fixed wrong objectID parameter export for volumes causing wrong ObjectID and MultiMatte render elements output
  • When Motion Blur is disabled and Duration is set to 0, the geometry disappears
  • Alembic paths were not exported correctly for alembic files containing 2 frame samples in a single frame abc file
  • Some V-Ray Frame Buffer settings were not stored in the scene or went missing when opening it in non-GUI mode
  • Fixed wrong "Display" parameter evaluation when the parameter is animated
  • Updated Wrapper material, Object Properties and Volume Grid Shader parameters to fix a wrong export issue with the Volume GI properties
  • In some cases duplicate geometry was exported to the VRScene for every packed primitive
  • Locked the "Min. Geometry Samples" option for Motion Blur to 2
  • Object with animated "Renderable" parameter in the V-Ray Object Properties is not rendered
  • In some cases the live geometry instancing will fail producing large VRScene files
  • Objects with animated visibility are always visible
  • Wrong evaluation for "${F}" when used in an expression for the "Environment" parameter on the V-Ray Renderer ROP
  • Fixed a problem in a specific scene where the animated mesh vertices would not be exported
  • Displacement through material is not exported when some of the faces have a shader with no displacement assigned to them
  • Added support for a default material and default texture export under the Options tab of the V-Ray Renderer ROP
  • Fixed an assignment mis-match when using shop_materialpath on packed primitives in a specific scene
Volume Grid
  • Phoenix FD ".aur" cache files produced wrong emission results
  • Preserve environment variables functionality on the ROP was working incorrectly for volumes
V-Ray
  • Fixed a difference in Motion Blur when using the "v" attribute if Rayserver Instancer is enabled
  • Crash when the Chaos License Server is not installed and trying to select GPU Devices
Aerial Perspective
  • The V-Ray Sun was missing
Textures
  • Object level transformations were not considered by the V-Ray Distance Texture for geometry in the "Objects" list
  • Fixed a bug preventing the re-loading of an OSL file in the OSL texture
  • Added some missing UV Bercon parameters
  • UVWGenEnvironment has horizontal and vertical rotations swapped
  • OSL string widgets do not generate a drop-down menu for TexOSL
  • The Distance Texture was not picking up instanced objects in IPR
  • Fixed a displacement texture export issue when no file path is provided
  • Make Transform VOP data was not exported to the VRScene
  • Wrong UVs export when displacement is enabled
  • Removed the "Filtering Strength" parameter from the UV Bercon VOP
  • Changed the Reference Shader VOP's Node parameter to 'oppath' instead of 'oplist'
  • Added a name parameter for each layer of the Layered texture
  • Fixed a bug causing UV stretching when using OpenSubdiv
  • Added support for all common Image File VOP output sockets when OCIO is enabled
  • Texture in a V-Ray Image node connected to the Displacement VOP doesn't override the texture in the displacement node
  • Fixed a crash when the Volume Grid texture's Path parameter is empty or incorrect
  • Fixed an issue with the Image File VOP causing OCIO texture colorspace parameter menus to not be populated automatically
  • The OCIO configuration used to be parsed per-texture instead of globally which produced noticeable slowdowns when opening a scene that contains a large number of V-Ray OCIO VOPs
  • Crash when no UV Mapping VOP is connected to the V-Ray Bercon Noise VOP
Displacement
  • File sequence textures with an e.g. <frame4> token in the file path would not be loaded when specified directly under the Displacement VOP's Texture parameter
VRProxy
  • Proxy created from Packed Geometry has wrong Viewport preview when imported back into the scene
UI
  • The Physical Camera "Rolling Shutter" parameter had an unreasonable default value
  • The V-Ray Bump material is present twice in the VOP menu with the copy causing a UI error
  • 2D displacement settings stay hidden when displacement type is set to 2D
  • Updated the GPU Device Select window borders
  • Removed "Work in Progress" UI prefixes for new features
  • Added missing "End Tangents" toggle to the Bercon textures
  • The Physical Camera "ISO" parameter should not be disabled for CUDA/RTX render modes
Chaos Cloud
  • Fixed a crash when submitting to the Chaos Cloud without a camera in the scene
Rendering
  • Fixed a crash with particles and Rayserver Instancer when Motion Blur is enabled, velocity is used and Sampler Max Subdivs is greater than 11
  • Fixed a bug causing wrong EXR Metadata export due to ticks (`) in the string field
  • Fixed a bug causing no motion blur with non-default Motion Blur settings on CentOS 7 with Houdini 17.5
  • Car Paint material was missing a "flake_uvwgen" input
  • Environment texture parameters were not exported when no input node is provided to the input slot causing V-Ray to use the "background" texture
  • Added a "Save Deep Data to Separate Files" toggle on the V-Ray Renderer ROP's Images -> Advanced tab
  • Rendering splines with V-Ray GPU would produce dark artifacts on the hairs in some scenes that contain a V-Ray Rect or Sphere light
  • Crash on render start under Mac OSX
Volume
  • Fixed a bug causing wrong VRScene export for volume sequences loaded as Packed Disk Primitive types
  • Fixed wrong objectID parameter export for volumes causing wrong ObjectID and MultiMatte elements output
  • Duplicate "Disabling Light Cache for ..." message printed for volumes even when Volume Light Cache is disabled when rendering in IPR
Volumes
  • Fixed a crash when rendering volumes instanced over points with a @pscale of 0
Houdini
  • Fixed a bug causing the Houdini “hou” python module to fail loading when starting Houdini in batch
  • Fixed an issue with the V-Ray TOP node caused by using a relative, rather than absolute path in the VRayTOP HDA
  • Referenced parameters are sometimes not evaluated for the V-Ray Renderer ROP when placed inside a locked HDA
  • Referenced python expressions would sometimes not be evaluated correctly for the V-Ray Renderer ROP
  • The "Pack Scene" option from the V-Ray menu used to crash Houdini when used on an empty scene with no V-Ray Renderer ROP present
Lights
  • Lights instanced over template points do not disappear if the template point is removed during animation
  • Fixed a crash on render end with instanced Mesh lights
  • Fixed HDA errors thrown by Mesh light when attempting to create a digital asset
  • Sphere and IES lights were not exported to the VRScene
  • Fixed a bug causing instanced lights to emit no light in the scene
Materials
  • Light links are not considered by the Volume Scatter material
  • Fixed an issue with Dispersion when using the acesCG color space
  • Fixed a bug causing scrambled material assignments when assigning a Multi ID Material to a mesh with OpenSubdiv enabled from the Object Properties
VRScene
  • Materials are not re-built correctly when importing them from a VRScene that uses the parameter::socket notation
  • Crash when importing material from VRScene generated in Houdini using the "Plugin Name" option
  • Empty material import with VRScenes generated from Houdini when using the "Scene Name" option
