This page provides information on the VRayMtlCarPaint node.
The VRayMtlCarPaint node is a material that simulates a metallic car paint. It is a complex material with four layers: a base diffuse layer, a base glossy layer, metallic flakes layer, and clear coat layer. The material allows the adjustment of each of these layers separately. The node has several parameters that can be controlled via a texture. In the interface they can be recognized by the checkbox to the right of the color or value picker.
UI Path: ||Toolbar|| > V-Ray menu icon > Materials > VRayMtlCarPaint
Basic Parameters
Base Color – The diffuse color for the base layer. (Can be mapped by enabling the check box to the right. This will create a new input for the current node.)
Base Reflect – The reflectivity of the base layer. The reflection color itself is the same as the Base color. (Can be mapped by enabling the check box to the right. This will create a new input for the current node.)
Base Glossiness – Reflection glossiness for the base layer. (Can be mapped by enabling the check box to the right. This will create a new input for the current node.)
Map Type – Specifies whether a bump map or a normal map effect will be added to the base material.
Bump Map
Normal map in tangent space
Normal map in objectspace
Normal map in screen space
Normal map in worldspace
Base Bump Map – Specifies the bump/normal map that is going to be used. (Can be mapped by enabling the check box to the right. This will create a new input for the current node.)
Base Bump Mult – A multiplier for the bump/normal effect.
Base Trace Reflection – Toggle reflections for base layer.
Flakes Parameters
Flake Color – The color of the metal flakes. (Can be mapped by enabling the check box to the right. This will create a new input for the current node.)
Flake Glossiness – The glossiness of the metal flakes. It is not recommended to set this above 0.9 as it may produce artifacts. (Can be mapped by enabling the check box to the right. This will create a new input for the current node.)
Flake Orientation – Controls the orientation of the flakes relative to the surface normal. When this is 0.0, all flakes are perfectly aligned with the surface. When it is 1.0, the flakes are rotated completely randomly with respect to the normal. Values above 0.5 are not recommended as they can produce artifacts. For more information, see The Flake Orientation Parameter example below.
Flake Density – The density (number of flakes) for a certain area. Lower values produce less flakes and higher values produce more flakes. Set this to 0.0 to produce a material without flakes. For more information, see The Flake Density Parameter example below.
Flake Scale – Scales the entire flake structure. For more information, see The Flake Scale Parameter example below.
Flake Size – The size of the flakes relative to the distance between them. Higher values produce bigger flakes and lower values produce smaller flakes. For more information, see The Flake Size Parameter example below.
Flake Map Size – Internally the material creates several bitmaps to store the generated flakes. This parameter determines the size of the bitmaps. Lower values reduce RAM usage, but may produce noticeable tiling in the flake structure. Higher values require more RAM, but tiling is reduced. Be careful when using the Directional filtering method, as it may quickly take up gigabytes of RAM for larger map sizes.
Flake Filtering Mode – Determines the way the flakes are filtered. Filtering is extremely important to reduce the work required to produce a clean image. See the Examples for a demonstration of this parameter. The possible values are:
simple – This method is faster and uses less RAM but is less accurate. It averages the orientation of the flakes together, which may alter the appearance of the material when viewed from a distance.
directional – This method is slightly slower and uses more RAM but is more accurate. It groups the flakes based on their orientation before performing the filtering, so that the material appearance is preserved.
For more information, see The Flake Filtering Parameter example below.
Flake Seed – The random seed for the flakes. Changing this produces different flake patterns.
Mapping Type – Specifies the method for mapping the flakes. The possible values are:
Explicit mapping channel – The flakes are mapped using the specified channel.
Triplanar projection in object space – The material automatically computes mapping coordinates in object space based on the surface normals.
Mapping channel – The mapping channel for the flakes when the Mapping Type is set to Explicit mapping channel.
Flake Trace Reflections – Toggles reflections for flake layer.
Example: The Flake Orientation Parameter
This set of images demonstrate the effect of the Flake orientation parameter. Note how lower values produce flakes more aligned with the surface normal, so that light is reflected more uniformly. Higher values produce more random flakes leading to more variation in the flake illumination.
Flake orientation is 0.0
Flake orientation is 0.1
Flake orientation is 0.3
Example: The Flake Density Parameter
This set of images shows the effect of the Flake density parameter. Note how larger values produce more flakes, but do not change the flake size.
Flake density is 0.5
Flake density is 1.0
Flake density is 2.0
Example: The Flake Scale Parameter
This set of images demonstrate the effect of the Flake scale parameter. Note how lower values scale the entire flake structure.
Flake scale is 0.005
Flake scale is 0.01
Flake scale is 0.02
Example: The Flake Size Parameter
This set of images shows the effect of the Flake size parameter. Note how larger values make the individual flakes larger, but do not change their count.
Flake size is 0.5
Flake size is 1.0
Flake size is 2.0
Example: The Flake Filtering Parameter
This example shows the effect of the Flake filtering parameter.
No filtering and no antialiasing; the result is very noisy because of the small flake size.
No filtering, Adaptive DMC antialiasing. The result is accurate, but very slow since a lot of AA samples are required to antialias the flakes.
Flake filtering set to Simple, no antialiasing. The filtering greatly reduces the noise, but alters the appearance of the material.
Flake filtering set to Directional, no antialiasing. The noise is reduced and the material appearance is correctly preserved.
Example: Antialiasing Filters
Here is an example briefly demonstrating the effect of different antialiasing filters on the final result.
Note that rendering with a particular filter is not the same as rendering without a filter and then blurring the image in a post-processing program like Adobe Photoshop. Filters are applied on a sub-pixel level, over the individual sub-pixel samples. Therefore, applying the filter at render time produces a much more accurate and subtle result than applying it as a post effect. V-Ray can use all standard 3ds Max filters (with the exception of the Plate match filter) and produces similar results to the scanline renderer.
The Adaptive image sampler was used for the images below, with Min/Max rate of -1/3 and the Rand option on.
Simple filtering
Flake map size is 256.
Flake maps take less than 1 MB.
Simple filtering
Flake map size is 512.
Flake maps take between 1 and 2 MB.
Simple filtering
Flake map size is 1024.
Flake maps take 5 MB.
Simple filtering
Flake map size is 2048.
Flake maps take 21 MB.
Flake maps take 10 MB.
Flake maps take 40 MB.
Flake maps take 161 MB.
Flake maps take 645 MB.
Other
Coat Parameters
Coat Color – The color of the coat layer. (Can be mapped by enabling the check box to the right. This will create a new input for the current node.)
Coat Strength – The strength of the coat reflections when the surface is viewed directly from the front.
Coat Glossiness – Glossiness of the coat reflections. (Can be mapped by enabling the check box to the right. This will create a new input for the current node.)
Map Type – Choose between several types of Normal Maps and Bump map.
Coat Bump Map – A slot for the bump or normal map. (Can be mapped by enabling the check box to the right, this will create a new input for the current node.)
Coat Bump Mult – A multiplier for the bump or normal map.
Coat Trace Reflections – Toggle reflections for coat layer.
Options
Cutoff Threshold – Cutoff threshold for the reflections of the different layers.
Double Sided – When enabled, the material is double-sided.
Trace Reflections – Global switch to toggle reflections for all layers.
Max Depth – The number of times a ray can be reflected.
