Build 5.20.00
Official release
Date  2 December, 2021
Download V-Ray for Nuke
New Features and Improvements
  • Support for Nuke 13.0
VRayVolumeGrid
  • Support for asynchronous loading of simulation cache and viewport preview
VRayCamera/VRayScene
  • Allow camera transform and parameter override from render camera in vrscene
  • VRayStandalone with VFB2 support
  • Redesigned installer
Modified Features and Bug Fixes
  • VRayTexBitmap texture output format is affected by the project setting format
  • Animated TexBitmap does not render on GPU via VRayStandalone
  • Missing exported keyframe with motion blur duration below 1 frame
  • Light linked via LightLinker as included type but without linked objects affects non-linked objects
  • Incorrect output of Project3D using native Nuke texture on GPU
  • Pixel outside projection view via Project3D using native Nuke texture is not transparent
  • Random failing VRayTranslator export with "Unable to write to file, empty vrscene filename" message
Build 5.00.00
Official release
Date – 14 October, 2020
  • Support for Nuke 12.2
  • VRaySunSky : Added "Improved" sky model
  • VRaySunSky : Added albedo blend angle and horizontal offset and regroup all albedo options in a new Ground Albedo rollout.
  • VRayRenderElement (LightSelect) : Added Light Path Expressions (LPE)
  • VRayRenderElement (LightSelect) : Added Indirect and Subsurface light select mode
  • VRayMtl : Added Coat layer
  • VRayMtl : Added Sheen layer
  • VRayMtl : Added Metalness
  • VRayEnvironmentFog : Added colored transparency
  • VRayPluginMtl : Implemented VRayPlugin-based generic material node with automatic user interface creation based on plugin description
