© Bertrand Benoit
This page provides information on the native Unreal Materials and Material Instances.
V-Ray for Unreal support the rendering of native Unreal Materials and Material Instances. Materials are used to calculate how light interacts with surfaces. These calculations are done using incoming data that is input to the Material from a variety of images (textures) and math expressions, as well as from various property settings inherent to the Material itself. Each time a change is made in the material it has to recompile which can be very time consuming depending on the complexity of the shading graph. Material instancing is used to change the appearance of a Material without incurring an expensive recompilation of the Material using predefined parameters. For more information on Unreal Materials and Material Instances check the Materials documentation.
Supported Expressions
Below are listed the expressions in the Material Editor that are supported by V-Ray for Unreal.
Native Unreal Materials are supported in Hybrid rendering. Make sure you meet the System Requirements.
Expression NameSupport
AtmosphericFogColor
NOT SUPPORTED
Constant
SUPPORTED
Constant2Vector
SUPPORTED
Constant3Vector
SUPPORTED
Constant4Vector
SUPPORTED
DistanceCullFade
NOT SUPPORTED
ParticleColor
NOT SUPPORTED
ParticleDirection
NOT SUPPORTED
ParticleMotionBlurFade
NOT SUPPORTED
ParticleRadius
NOT SUPPORTED
ParticleRelativeTime
NOT SUPPORTED
ParticleSize
NOT SUPPORTED
ParticleSpeed
NOT SUPPORTED
PerInstanceFadeAmount
NOT SUPPORTED
PerInstanceRandom
NOT SUPPORTED
Time (info)
PARTIAL
TwoSidedSign
SUPPORTED
VertexColor
SUPPORTED
View Property (info)
PARTIAL
Precomputed AO Mask
NOT SUPPORTED
LightmapUVs
NOT SUPPORTED
 ObjectRadius
SUPPORTED
Panner
SUPPORTED
ParticlePositionWS
NOT SUPPORTED
Rotator
SUPPORTED
SceneTexelSize
NOT SUPPORTED
ScreenPosition
SUPPORTED
TextureCoordinate (info)
PARTIAL
ViewSize
NOT SUPPORTED
WorldPosition
 SUPPORTED
Custom
NOT SUPPORTED
DepthFade
NOT SUPPORTED
 PixelDepth
SUPPORTED
SceneDepth
NOT SUPPORTED
FunctionInput
SUPPORTED
FunctionOutput
SUPPORTED
MaterialFunctionCall
SUPPORTED
StaticBool
SUPPORTED
StaticSwitch
SUPPORTED
BreakMaterialAttributes
SUPPORTED
GetMaterialAttributes
SUPPORTED
MakeMaterialAttributes
SUPPORTED
SetMaterialAttributes
SUPPORTED
Abs
SUPPORTED
Add
SUPPORTED
AppendVector
SUPPORTED
 Arccosine
SUPPORTED
ArccosineFast (info)
PARTIAL
 Arcsine
SUPPORTED
ArcsineFast (info)
PARTIAL
 Arctangent
SUPPORTED
 Arctangent2
SUPPORTED
Arctangent2fast (info)
PARTIAL
ArctangentFast (info)
PARTIAL
Ceil
SUPPORTED
Clamp
SUPPORTED
ComponentMask
SUPPORTED
Cosine
SUPPORTED
CrossProduct
SUPPORTED
Divide
SUPPORTED
DotProduct
SUPPORTED
Floor
SUPPORTED
Fmod
SUPPORTED
Frac
SUPPORTED
If
SUPPORTED
LinearInterpolate
SUPPORTED
Logarithm10
NOT SUPPORTED
 Logarithm2
SUPPORTED
Max
SUPPORTED
Min
SUPPORTED
Multiply
SUPPORTED
Normalize
SUPPORTED
OneMinus
SUPPORTED
Power
SUPPORTED
Round
SUPPORTED
Saturate
SUPPORTED
Sign
SUPPORTED
Sine
SUPPORTED
SquareRoot
SUPPORTED
Subtract
SUPPORTED
 Tangent
SUPPORTED
Truncate
SUPPORTED
CollectionParameters
NOT SUPPORTED
DynamicParameter
NOT SUPPORTED
FontSampleParameter
NOT SUPPORTED
ScalarParameter
SUPPORTED
StaticBoolParameter
SUPPORTED
StaticSwitchParameter
SUPPORTED
StaticComponentMaskParameter
NOT SUPPORTED
VectorParameter
SUPPORTED
TextureObjectParameter
SUPPORTED
TextureSampleParameter2D
SUPPORTED
TextureSampleParameterSubUV
NOT SUPPORTED
TextureSampleParameterCube
NOT SUPPORTED
TextureSampleParameterMovie
NOT SUPPORTED
DynamicParameter
NOT SUPPORTED
ParticleColor
NOT SUPPORTED
ParticleDirection
NOT SUPPORTED
ParticleMacroUV
NOT SUPPORTED
NOT SUPPORTED
ParticlePositionWS
NOT SUPPORTED
ParticleRadius
NOT SUPPORTED
NOT SUPPORTED
ParticleSize
NOT SUPPORTED
ParticleSpeed
NOT SUPPORTED
SphericalParticleOpacity
NOT SUPPORTED
ParticleSubUV
NOT SUPPORTED
LanscapeLayerBlend
NOT SUPPORTED
LandscapeLayerCoords
NOT SUPPORTED
LandscapeLayerSwitch
NOT SUPPORTED
LandscapeLayerWeight
NOT SUPPORTED
LanscapeVisibilityMask
NOT SUPPORTED
FontSample
NOT SUPPORTED
SceneColor
NOT SUPPORTED
SpriteTrextureSampler
NOT SUPPORTED
TextureObject
SUPPORTED
TextureSample
SUPPORTED
TextureProperty
NOT SUPPORTED
AntialiasedTextureMask
NOT SUPPORTED
BlackBody
NOT SUPPORTED
BumpOffset
SUPPORTED
ConstantBiasScale
SUPPORTED
DDX (info)
PARTIAL
DDY (info)
PARTIAL
DepthOfFieldFunction
NOT SUPPORTED
Desaturation
SUPPORTED
Distance
SUPPORTED
DistanceFieldGradient
NOT SUPPORTED
DistanceToNearestSurface
NOT SUPPORTED
FeatureLevelSwitch
NOT SUPPORTED
Fresnel
SUPPORTED
GIReplace
NOT SUPPORTED
LightmassReplace
NOT SUPPORTED
Noise
NOT SUPPORTED
PreviousFrameSwitch
NOT SUPPORTED
QualitySwitch
NOT SUPPORTED
RayTracingQualitySwitch (info)
PARTIAL
RotateAboutAxis
SUPPORTED
SphereMask
SUPPORTED
Vector Noise
NOT SUPPORTED
ActorPositionWS
NOT SUPPORTED
CameraPositionWS
SUPPORTED
CameraVectorWS
SUPPORTED
DeriveNormalZ
NOT SUPPORTED
LightVector
NOT SUPPORTED
ObjectBounds
NOT SUPPORTED
ObjectOrientation
NOT SUPPORTED
ObjectPositionWS
SUPPORTED
ParticlePositionWS
NOT SUPPORTED
PixelNormalWS
SUPPORTED
Pre-Skinned Local Normal
NOT SUPPORTED
Pre-Skinned Local Position
NOT SUPPORTED
ReflectionVectorWS
SUPPORTED
Transform
SUPPORTED
TransformPosition
PARTIAL
VertexNormalWS
SUPPORTED
If the Coordinate Index in the TextureCoordinate node in a material is set to a certain value and the material is applied to a Static mesh that doesn't have a corresponding UV channel, then that mesh will not render correctly in V-Ray. For example, the Coordinate Index in a material that is applied to a static mesh is set to 3 but the mesh has only 2 UV channels then the render result will be inaccurate.
Supported Material Inputs, Blend Modes and Shading Models
Below are listed all inputs, Blend modes and Shading models in the Material Editor that are supported by V-Ray for Unreal.
Inputs
Base Color
SUPPORTED
Metallic
SUPPORTED
Specular
SUPPORTED
Roughness
SUPPORTED
Emissive Color
SUPPORTED
Opacity
SUPPORTED
Opacity Mask
SUPPORTED
Normal
SUPPORTED
World Position Offset
NOT SUPPORTED
World Displacement
NOT SUPPORTED
Tessellation Multiplier
NOT SUPPORTED
Subsurface Color
SUPPORTED
Clear Coat
SUPPORTED
Clear Coat Roughness
SUPPORTED
Ambient Occlusion
NOT SUPPORTED
Refraction
NOT SUPPORTED
Pixel Depth Offset
NOT SUPPORTED
Shading Model
NOT SUPPORTED
ClearCoatBottomNormal
SUPPORTED
Blend Modes
Opaque
SUPPORTED
Masked
SUPPORTED
Translucent
SUPPORTED
Additive
NOT SUPPORTED
Modulate
NOT SUPPORTED
Alpha Composite
SUPPORTED
Shading Modes
Unlit
SUPPORTED
Default Lit
SUPPORTED
Subsurface
SUPPORTED
Preintegrated Skin
NOT SUPPORTED
Clear Coat
SUPPORTED
Subsurface Profile
NOT SUPPORTED
Two Sided Foliage
SUPPORTED
Hair
NOT SUPPORTED
Cloth
NOT SUPPORTED
Eye
NOT SUPPORTED
