Windows
Please make sure that your system fulfills these requirements before installing V-Ray. Note that V-Ray is only supported for 64 bit operating systems and 64 bit versions of Revit. For additional information on hardware, see the Hardware Recommendations article.
Processor
minimum: Intel® 64, AMD® 64 or compatible processor with AVX2 support;
recommended: Intel® 64, AMD® 64 or compatible processor with AVX2 support. Larger cache memory, higher memory bandwidth and more cores are better.
RAM
minimum 8 GB RAM, recommended 16 GB RAM
Hard Disk Space
minimum 2GB, recommended 12GB (includes additional downloadable content)
TCP/IPOnly IPv4 is supported. IPv6 is currently not supported
Operating system
Windows 10, Windows 11
RevitAutodesk Revit 2022, 2023, 2024, 2025, and 2026.
GPU Support
NVIDIA GPUs of Maxwell generation or later with the latest recommended video driver (for both CUDA and RTX - enabled cards)
V-Ray Vision requires a Graphics card with DirectX 11 or DirectX 12 and Shader Model 5.0 capabilities
CUDA compute capability and card reference
** Windows 11 is required for running Intel Alder Lake processors.
