Build 6.10.06
Official release
Date - 16 JAN, 2025
Download V-Ray for Revit
Improvements
  • General: Updated License Server 6.2.0
Build 6.10.05
Official release
Date - 25 JUN, 2024
Improvements
  • General: Added support for Revit 2025
  • General: Chaos Cosmos Browser updated to version 2024.06.19
  • General: Chaos Cloud Client updated to version 1.29.3
Bug fixes
  • General: Fixed issue with RPCs disappearing from rendering in Revit 2024
Build 6.10.04
Official release
Date - 14 FEB, 2024
Bug Fixes
General
  • Revit 2024 toposolid cannot be added as a Scatter host
  • Null reference exception on rendering after switching design options
  • UnitTypeld is not a unit identifier error when enabling V-Ray
Build 6.10.03
Official release
Date - 13 JUL, 2023
Improvements
General
  • Added support for Revit 2024
  • Asset Editor updated to version 3.1.0
  • License Server updated to version 6.0.1
  • Unified Login Application updated to version 2023.1.18
  • Chaos Cosmos Browser updated to version 2023.7.10
  • Chaos Cloud Client updated to version 1.26.0
  • Optimized scene upload to Chaos Cloud
Environment
  • Added Contrails settings to the V-Ray Sun panel
Assets/Enscape
  • Support Enscape Adjustable assets
  • Included the Enscape 3D assets to the global material override
  • Custom Enscape assets’ materials render in albedo color if their texture file is missing
Materials
  • Use Revit Shading Colors takes priority over Render Enscape Materials
UX/UI
  • Removed deprecated Trace Depth option from the Interactive Settings rollout of the Renderer tab and added Max Trace Depth option to the Optimizations rollout
  • Added dark mode toolbar icons when the Revit UI theme is set to dark
  • Added a scrollbar to the V-Ray Lights panel, and improved the one in the Settings panel
Bug fixes
 General
  • Name cannot include prohibited characters exception on project migration
  • NullReferenceException when importing settings containing references to legacy V-Ray 3.7 or older materials
Assets/Enscape
  • Enscape asset 'Bamboo 005: Single Cane' renders trunk and leaves in different places
  • Rendering doesn't update on artificial lights changes
  • Dispatcher exception after deleting a light in a complex project
  • Lights are copied instead of moved
  • Moving a cosmos light does not update the light sources and moves only the asset geometry
Appearance Manager
  • Materials' tab dot indicators remain after deleting Fur/Displacement
  • Rotation min field in the Families tab doesn't accept 0 input
Cosmos Assets
  • Some ceiling-based Cosmos assets are offset from the host in the viewport
UX/UI
  • Materials modified in the Enscape editor are not indicated in orange in the Appearance Manager
Build 6.00.02
Official release
Date - May 2, 2023
Improvements
General
  • Updated EULA
Bug fixes
General
Build 6.00.01
Official release
Date - DEC 07, 2022
Improvements
General
  • Integrated Chaos Cloud Collaboration service
  • Chaos Cosmos Browser updated to version 2022.11.15
Environment
  • Default Sky Model changed to PRG Clear Sky
  • Added options to animate the procedural clouds in solar studies
Environment/Enscape
  • Added options to transfer the Enscape cloud settings to V-Ray
Asset Editor
  • Added ability to search across tags
Bug fixes
Materials/Enscape
  • Transmissive color of the Revit Glazing materials is ignored in the V-Ray render
Geometries
  • Displacement Amount and Shift are not considered by the V-Ray Decal
Asset Editor
  • Fixed issue with the Exclude and Affected by options of the Dirt texture
UX/UI
  • Exception when loading user settings and collapsing the groups of loaded settings
Build 6.00.00
Beta release
Date - NOV 3, 2022
Improvements
General
  • Asset Editor updated to version 3.0.0
  • Chaos Cloud client updated to version 1.20.2
  • Chaos Cosmos Browser updated to version 2022.11.2
  • Chaos License Server updated to version 6.0.0
  • Added ability to render Enscape materials with V-Ray
  • Added ability to render Enscape library 3D models with V-Ray
  • Added support for the Light Cache GI engine in Interactive
  • Dropped support for Revit 2018
  • Dropped support for Windows 8
Materials
  • Added ability to promote Enscape materials to the Asset Editor
  • Improved conversion of Revit’s Generic material type
  • Added ability to promote Revit Generic materials to the Asset Editor
  • Improved texture paths compatibility with Revit
  • Added ability to create a V-Ray Decal
  • Migrated the V-Ray Material Library to Chaos Cosmos
  • Added Thin Film material layer
  • Extended the Dirt texture with options for more precise control
  • Improved reflections for metals and rough reflective surfaces
  • Improved translucent materials
  • Implemented Car Paint 2 material
Geometries
  • Added View & Override replacement options for Scatter
  • Added ability to pick a geometric face as a Scatter host
Environment
  • Added procedural clouds settings to the V-Ray Sun panel
  • Added finite mode for the Dome Light
Camera
  • Enabled the Auto options in Interactive
VFB
  • Added a panorama viewer for spherical panorama renders
  • Added proportion guide layer
  • Added ability to flip the image horizontally or vertically
  • Added ability to color correct a batch of pre-rendered images at once
  • Added Dither colors option to the Render View tab of the VFB Settings panel
  • History state is preserved between installations
Asset Editor
  • Implemented asset tagging system
  • Added a Sphere preview to the material preview swatch presets
  • Added Automatic Transfer Function mode to the Bitmap texture
  • Added Mix Amount parameter to the Mix (Operator) texture
  • Renamed the Bitmap Texture Color Space to Transfer Function
  • Increased the slider precision of the Reflection and Refraction Glossiness, and Metalness parameters of the Generic material
  • Added Local Space Bump mode to all materials that support bump mapping
  • Removed the upper limit of the Emissive material Intensity parameter
  • Disabled the automatic texture resize for the GPU asset preview
UX/UI
  • Added ability to drag & drop Cosmos materials to the Appearance Manager
  • Improved the bottom toolbar instructions for actions with Scatter
Bug fixes
General
  • Error in GUI on V-Ray standalone start
  • Batch render fails to start if the autosave path has been deleted
  • Installing Chaos Vantage v.1.7.1 breaks the Cosmos browser
  • System.Net.WebException on attempt to import Cosmos 3D models
Materials
  • Pick Material does not detect Revit split faces
Geometries
  • Proxy Mesh material slots fail to generate in case of a .vrmesh containing a single material
  • Disabling Proxy Mesh Materials from within the Asset Editor is not respected
  • Show Mass options of the Massing & Site menu is not respected
Textures
  • Normal maps rotated by the UVWGenRandomizer appear inverted in some situations
Asset Editor
  • V-Ray NeUI fails to load VRaySDKLibrary.dll resulting in blank V-Ray Asset Editor
Scatter
  • Guest instances sink into the Host when it contains layers
  • Families containing nested RPCs are incorrectly scattered
VFB
  • The Exposure (display only) slider part of the Display Correction’s layer parameters affects images saved from the VFB
UX/UI
  • Fixed several tooltips in the Appearance Manager
