Official Release
Date – December 2, 2019
Download – 4.00.03
Improvements
General
  • Updated the Chaos Cloud client app installer to version 1.6.2
  • Implemented log rotation (last 10 log files are kept)
 Appearance Manager
  • Asset Browser renamed to Appearance Manager
  • Added scale settings to Proxies materials
  • Ability to lock Width and Height of materials
  • Expand Revit material names when expanding the window horizontally
  • Increased width of V-Ray materials drop-down
Camera
  • Focus Source is switched automatically after Pick Focus Point has been selected
Bug fixes
General
  • Exception with DefaultSettings.xml becoming unaccessable/being used by another process
  • Exception on attempt to render .rfa files
  • VRayExtensibleStorage exception Material Plugins already contain <plugin name>
  • Fields that use the project units are not properly updated
 Materials
  • Modifying assigned materials doesn't cause an update during Interactive Rendering
Asset Editor
  • Asset Editor is minimized when Render Progress window is minimized
  • InvalidOperationException/No process is associated with this object
  • Creating Blend material with Bump produces incorrect material plugins
  • Textures' UV Channel parameter is not properly updated during Interactive Rendering
 Swarm
  •  Select all/none tags does not update the tags highlights
