Beta 1
Date – Sep 18 , 2019
Download – 4.00.01
Improvements
General
  • Added support for Revit 2020.
  •  Added support for Revit Decals including interactive actions.
  • Implemented linking and rendering of .vrscene files.
  • V-Ray Core updated to version 4.20.01.
  • License Server updated to version 5.2.2.
  • Implemented V-Ray settings storage within the Revit project file. Removed .vprops files.
  • Implemented options to adopt co-workers’ V-Ray settings when in workshared Revit environment.
Material Editor
  • V-Ray Asset Editor replaces the Vrmat editor, introducing new material workflow and variety of material types.
Asset Browser
  • Fully redesigned UX/UI.
  • Removed Color and Texture options from the material mapping controls.
  • Integrated new material mapping controls with a drop-down listing all project V-Ray materials.
  • Added Revit Shading as a mode for Global material overrides.
  • Added option to keep materials’ bump/displacement pattern on global material override.
  • Added option for V-Ray Scenes material override.
  • Added option to hide all RPCs from rendering.
  • Added option to hide all Revit Decals from rendering.
Proxies
  • Exposed additional Revit family categories to the proxy Objects tab (Furniture, Furniture Systems, Generic Models, Casework)
  • Exposed proxies settings in the corresponding UI tab.
  • Integrated Randomizer for scale and rotation parameters of Proxies/V-Ray Scenes.
V-Ray Fur
Exposed V-Ray Fur settings in the corresponding UI tab.
Materials/AutoGen
  • Added support for Revit’s PrismGlazing material type.
  • Improved the automatic conversion of all Revit Prism materials.
Camera
  • Added options for automatic Exposure and White Balance.
  • Added option to select the Focus Source.
  • Added Pick Focus Point option to the Camera tab of the V-Ray toolbar.
  • Added Use Revit Far Clip setting under Settings/Renderer tab/Optimizations.
Lights
  • Combined all environment light settings into one V-Ray Lights dialog.
  • Added Adaptive Dome Light setting under Settings/Renderer tab/Optimizations.
  • Improved Revit artificial lights conversion.
  • Added custom background settings to V-Ray Lights window.
  • Added support for the visibility of Revit artificial lights’ emit shape.
  • Added Artificial Lights Overrides options to the Global Overrides tab.
  • Added North Indicator (N) and Camera Indicator (C) to HDR image previews.
Interactive Rendering
  • Improved stability of interactive updates.
  • Enabled V-Ray Light Cache in Interactive rendering mode.
  • Added support for showing/hiding elements.
  • Added support for Revit Background Style changes.
  • Support for interactive actions with V-Ray Scene files (experimental feature available through config.json file).
  • Implemented Default settings section under Settings/Paths & Sharing tab.
  • Implemented Reset to Default and Set As Default options.
  • Added V-Ray Material to Settings Sharing Categories.
  • Added support for buckets rendering on GPU.
  • Added Use global trace depth checkbox under Interactive settings.
  • Added Ambient Occlusion settings under Settings/Renderer tab/Global Illumination.
Channels
  • Organized all render channels in expandable groups.
  • Integrated Lighting Analysis channel.
  • Integrated MultiMatte Materials channel.
  • Integrated Nvidia AI denoiser as an alternative denoiser engine.
  • Added option to denoise individual channels.
  • Added standalone denoiser tool /vdenoise.exe/ to V-Ray for Revit tools folder.
  • Integrated RenderID channel.
  • Integrated Shadows channel.
  • Integrated Extra Texture channel.
VFB
  • Added context menu option to save out renders directly to the Revit project.
  • Incorporated rendering progress bar within the VFB window.
  • Reworked Lens Effects calculation and settings
Toolbar
  • Replaced all icons.
  • Removed Project Gallery window.
  • Added button to launch the Asset Editor.
  • Added feedback button to the expanding Help tab.
  • Added Show/Hide Render Progress button to the Render tab.
  • Removed Swarm icon.
UX
  • Size and location of V-Ray windows is saved on window reopen.
  • Extended the displayed version info in the V-Ray About window.
  • Added a link to VRayForRevit.log file in the About window.
  • Limited the minimal value for Camera Focus Distance.
  • Increased precision of Dome Light vertical offset.
  • Search boxes filter automatically on every key press.
  • V-Ray material name is highlighted in red in case of invalid or unresolved material.
  • Improved exceptions processing, reporting and logging.
  • Revit generic color is used in case of invalid AutoGen texture file.
  • Increased precision of Environment Fog Emission Multiplier.
  • Implemented dynamic sliders in Proxy/Vrscene settings.
  •  Organized linked project materials into expandable groups.
  • Organized Objects tab Revit families into expandable groups.
  • Organized Global Overrides settings into expandable groups.
  • Added Update button to Denoiser settings.
Bug fixes
General
  • Issue with Revit hanging during license acquiring.
  • Issue with windows appearance and positioning on high dpi monitors.
  • Exception on V-Ray license acquire with Revit 2017 and Windows 8.
  • Unhandled exception on re-render after switching from GPU to CPU.
  • Format exception when Windows decimal symbol is set to none.
  • Crash when trying to acquire license without an open Revit project.
  • Incorrect image size when overwriting an existing image in the Revit project.
  • Crash when sending telemetry about V-Ray Camera.
  • Exception when trying to write to V-Ray Telemetry log file.
  • Exception when adding warning/error messages to the render log.
  • Save V-Ray settings window pops up after Revit project save.
  • Wrong resolution when switching from Widescreen to Crop Region.
  • Add Path button opens unlimited number of browsing windows.
  • Buckets + Brute Force + Light Cache produces too much noise on Draft Quality preset.
  • Asset Paths list increases its height when adding more paths.
Swarm
  • Different render results when refractive objects overlap with other faces.
  • Exception when rendering a specific project.
  • Latest Render filter displays no materials if a change is made during IR.
  • Slowdowns caused by specific global override materials.
Lights
  • Zoom level changes on Dome Light image rotation/offset.
  • Some IES lights render differently on GPU vs CPU.
  • Memory leak when loading Dome Light images.
Materials/V-Ray
  • Starting material editor from the UI fails for some users.
  • Displacement is not respected on material swap in Interactive.
  • Displacement does not update in Interactive.
  • Unhandled exception when swapping vrmats with displacement.
  • Displacement map remains after the V-Ray material assignment is removed in Interactive.
  • Displacement map remains active on global material override.
  • Displacement causes unhandled exception when adjusting map size of materials in Interactive.
  • Issue with SSS materials disappearing in Interactive GPU.
  • Crash on global override with Dirt texture material.
  • Refraction max depth and exit color are not respected.
  • Some bitmap textures are not respected in Interactive GPU.
Materials/AutoGen
  • Error resolving default Revit textures file paths.
  • Fixed bug with Opaque material type parameters not being converted correctly to V-Ray.
  • Wood procedural texture is not rendered correctly by V-Ray.
  • Wavy bump of ceramic materials is not respected.
  • Glossiness conversion mismatches the Revit output.
  • Generic color is not respected when texture tiling is disabled.
  • Generic color is not respected when an alpha texture is used.
  • Incorrect positioning of non-tiled AutoGen textures.
  • Wrong conversion of marble procedural texture.
  • Wrong conversion of Revit water material.
  • Texture tiling set to None fails in Interactive GPU.
  • Broken water material reflections.
  • Water refraction does not render the pool bottom in a specific scene.
  • Use texture intensity when a texture is assigned to the reflectivity slot.
  • Exception when enabling Relief Pattern of Revit Masonry material without assigning an image.
  • Issue with Cutout textures disappearing in Interactive GPU.
Proxies
  • Crash when editing RPC Proxy material during Interactive rendering.
  • Enabling proxies in Interactive GPU fails every second time.
  • Crash when changing proxy material from .vrmat to color.
VFB
  • Crash when adding LUT files in Interactive.
  • Revit hangs on Interactive restart with Color Corrections panel open.
  • Copy to Stamp label is cut on high dpi monitors.
UI
  • Render in Chaos Cloud icon downscaled on high dpi monitors.
  • Long material names cause misalignment in the Asset Browser.
UX
  • Asset Paths Remove button remains active even if a path is not selected.
