Real-time Visualization
V-Ray Vision gives you a realistic real-time view of your model as you develop it. You can rapidly iterate, make better design decisions, and communicate more effectively with stakeholders working on the project.
Explore lighting like never before
With the new Light Mix feature, you can experiment with all the light sources in your scene after you have rendered. Group your lights, tweak their brightness, or change their color to find what best fits your space.
Post-process inside Revit
Our redesigned Frame Buffer comes with powerful new compositing and color corrections features. Now, you don’t need a separate app for these tasks — they can be handled with V-Ray and saved as presets for future projects.
Sketch ideas with a click
The new global Contours setting gives a sketch-like look to concepts that can be applied to the whole model or used selectively to highlight certain objects.
Streamlined proxy material setup
We've simplified the proxy material assignment process with the V-Ray Asset Editor. Assign materials in the Editor once, save them along with the mesh file and you can reuse this configuration in any project.
Add realism to Revit materials
Now, Displacement is not limited only to V-Ray materials — it’s an asset of its own that’s easy to apply to native materials.
More creative freedom with the Sun & Sky
In V-Ray 5, we give you more control over the sky generation parameters and access to our improved sky model which can be used for great-looking sunrises and sunsets.
Randomize textures for realism
Use the UVW Placement asset to randomize texture coordinates and colors of V-Ray materials as they would appear in the real world. And, with Stochastic Tiling, repeating patterns are a thing of the past.
Coat & Sheen Layers
Quickly create polished surfaces of your materials with the new Coat layer. Utilize the new Sheen layer to create realistic fabrics such as velvet, satin, or silk.
Dirt & Weathering
Add weathering effects to any surface of your model with the improved V-Ray Dirt texture.
Improved Material Library
Save time by downloading our render-ready Material library, containing over 500 high-resolution 4K textures such as glass, metal, wood, and many more.
