This page describes the Filter Generator for Lens Effects.
The Filter Generator is a simple tool for composing filters (HDR images in *.hdr format). It is specially designed to produce filters for the Lens Effects.
UI Path
||Start Menu|| > Filter generator tool
Installation
Windows: start the filter_generator executable from C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\vrayappsdk\bin.
For versions prior to V-Ray 7, start the filter_generator executable from C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\vrayappsdk\bin.
File Options
The file menu shows options for saving and loading presets and exporting the final filter kernel.
Radial Symmetric Pattern Parameters
The Radial Symmetric Pattern parameters control the scale of the overall Lens Filter.
Shape – Adjusts the size of the pattern.
Corona Flare Lines Pattern Parameters
The Corona Flare Pattern parameters control the amount of rays emanating from the light source.
Diametric – When enabled, mirrors the pattern across the center.
Radius – Controls the size of the pattern radius.
Number Of Lines – Controls the number of lines in the pattern.
This example demonstrates how different values of the Number of Lines parameter affect the lens effect. Increasing the Number of Lines value produces more rays emanating from the light source while decreasing it lowers the number of rays.
The last image also has the Diametric parameter enabled, which mirrors the rays pattern across the center (thus producing symmetrical flares).
Number Of Lines = 100, Diametric is off
Number Of Lines = 20, Diametric is off
Number Of Lines = 5, Diametric is off
Number Of Lines = 5, Diametric is on
Special Flare Lines Pattern Parameters
The Special Flare Pattern parameters control the pattern of the Special Flares Lines.
Ray Pattern Dropdown – Determines the number of Ray groups.
Radius – Scale of the Special Flares Lines Lens kernel in Percent.
Number of Lines – Determines the amount of lines used in each ray pattern.
Range – Controls the spread of the Ray Pattern.
Rotation – Rotates the entire Special Flare Lines Pattern in degrees.
This example shows the effect of Range and Ray Pattern parameters on the lens appearance. The Number of Lines is set to 10 for all images.
Number of Lines = 10, Range = 10, Ray Pattern = 2
Number of Lines = 10, Range = 10, Ray Pattern = 4
Number of Lines = 10, Range = 10, Ray Pattern = 6
Number of Lines = 10, Range = 10, Ray Pattern = 8
Number of Lines = 10, Range = 40, Ray Pattern = 2
Number of Lines = 10, Range = 40, Ray Pattern = 4
Number of Lines = 10, Range = 40, Ray Pattern = 6
Number of Lines = 10, Range = 40, Ray Pattern = 8
Number of Lines = 10, Range = 80, Ray Pattern = 2
Number of Lines = 10, Range = 80, Ray Pattern = 4
Number of Lines = 10, Range = 80, Ray Pattern = 6
Number of Lines = 10, Range = 80, Ray Pattern = 8
Lenticular Halo Parameters
The Lenticular Halo parameters control the bounds of the halo.
Inner Radius – Sets the inner bounds of the Lenticular Halo
Outer Radius – Sets the outer bounds of the Lenticular Halo.
This example shows how changing the inner and outer bounds values affects the Lenticular Halo.
Inner Radius = 20, Outer Radius = 40
Inner Radius = 20, Outer Radius = 60
Inner Radius = 20, Outer Radius = 80
Inner Radius = 20, Outer Radius = 120
Inner Radius = 40, Outer Radius = 120
Inner Radius = 80, Outer Radius = 120
Mix Parameters
The Mix parameters control how the Lens Parameters mix together into the final Filter kernel.
Pattern 1 – Sets the percentage Radial Symmetric Pattern 1 is mixed with the final Filter kernel.
Pattern 2 – Sets the percentage Radial Symmetric Pattern 2 is mixed with the final Filter kernel.
Halo – Sets the percentage the Lenticular Halo has on the final Filter kernel.
Aspect – Determines the Aspect Ratio of the final Filter kernel.
Apply Corona Flare Pattern – Enables kernel filtering with the Corona Flare Pattern.
Apply Special Flare Pattern – Enables kernel filtering with the Special Flare Pattern.
The following examples show how lens parameters can be mixed together to achieve a final filter kernel.
Apply Corona Flare Pattern is on, Halo = 0, Diametric is on, Number of Lines = 5
Apply Special Flare Pattern is on, Halo = 0, Number of Lines = 10, Range = 40, Ray Pattern = 6
Apply Corona Flare Pattern is on, Apply Special Flare Pattern is on, Halo = 0, Number of Lines = 10, Range = 40, Ray Pattern = 6
Apply Corona Flare Pattern is on, Apply Special Flare Pattern is on, Halo = 35, Number of Lines = 10, Range = 40, Ray Pattern = 6
Apply Corona Flare Pattern is on, Apply Special Flare Pattern is on, Halo = 70 Number of Lines = 10, Range = 40, Ray Pattern = 6
