This page provides information on the MultiMatte Materials Render Element.
The MultiMatte Materials Render Element creates red, green, and blue selection masks based on the material's ID number. Please note that this channel does not take into consideration Material's ID color.
With this render element, only three colors are possible: red, green, and blue. It analyzes the scene at render time and automatically creates the necessary number of channels based on the number of unique specified IDs. Each channel holds up to 3 unique IDs. Each channel's name indicates the IDs it represents.
With MultiMatte, a single R, G, or B channel can be used directly as a matte, eliminating the step of selecting the color in the compositing software. This ease of use makes MultiMatte a popular choice for compositors.
The MultiMatte Materials Render Element includes an antialiasing option.
Beside this render element, V-Ray also supports MultiMatte Objects channel, which uses Object ID numbers.
Beauty
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > MultiMatte Materials
||V-Ray Asset Editor|| > Create Asset (left-click) > Render Elements > MultiMatte Materials
How to Set Material IDs
Assign Material ID attribute from the Add Attribute button to all materials. Set ID numbers in the newly appeared rollout for each material.
You can select one ID number for more than one material in order to create a group of objects in the MultiMatte channel.
All items with the material assigned will be colored in the same color in this channel. See the result in the overview.
Common Uses
The MultiMatte Materials Render Element is useful for isolating Materials in a scene. While other matte render elements perform similar tasks, MultiMatte is often quicker to use in compositing software because it can be made to include only pure red, green, or blue channels to represent objects in the scene. Compositing software often has a feature for easily selecting the red, green, or blue channels in an image for use as mattes.
In this example, we set the pillow material ID as 1, the the sofa material ID as 2, and the blanket material ID as 3. Thus, masks are created in compositing to modify the isolated materials. See the render before and after compositing.
Before
After
  • Instances obtain the same object ID number of the copied object.
  • If objects with already assigned object IDs are grouped together and a new object ID is assigned to the group, the latter will override all separate IDs within the group.
  • If objects with already assigned object IDs become part of a block with a different object ID, the separate objects will preserve their initial object ID.
