This page provides information about the Environment Component in V-Ray for Grasshopper.
Input Parameters
Bg (AColorTex) – Choose a color or a texture to be visible as a background in the rendered image. If the other environment override slots are empty the background color/texture will also be used for global illumination and will be visible in reflections and refractions.
GI (AColorTex) – Choose a color or a texture to be used for environment light emission by the global illumination. If this environment override slot is empty the color/texture from the background will be used.
Reflection (AColorTex) – Choose a color or a texture to be visible in material reflections. If this environment override slot is empty the color/texture from the background will be used.
Refraction (AColorTex) – Choose a color or a texture to be visible through refractions. If this environment override slot is empty the color/texture from the background will be used.
Volumetric (Generic Data) – V-Ray Volumetric input expected. Multiple volumetric environment objects can be be connected at the same time.
Output Parameters
Env (Generic Data) – V-Ray Environment to be connected to the V-Ray Renderer's Environment input slot.
Examples:
Download the GH definition here.
