In V-Ray it is now possible to access the underlying scene plugins via the Rhino script tools.
A script access manual is provided with the installation of V-Ray. It can be found at the V-Ray for Rhino root folder C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\VRayForRhinoObjectModel.html
To use the V-Ray for Rhino wrapper module, add a new Python Module Search path pointing to C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros.
Alternatively, copy the rhVRay.py and rh8VRay.py file from C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros to %APPDATA%\McNeel\Rhinoceros\7.0\scripts and %APPDATA%\McNeel\Rhinoceros\8.0\scripts.
Due to the way V-Ray for Rhino communicates with its UI, certain "user data" parameters are employed while the actual scene parameters are set accordingly only at render time.
The precise names of such "user data" parameters can be found listed in exported V-Ray files:
  • for Settings - export a .vropt file
  • for Assets - export an asset of the required type as a .vrmat file
Their parameter handlers contain isUserData="1".
To set a parameter value in the V-Ray UI via a script, the "user data" counterpart must be used. Otherwise, the change will only affect the V-Ray scene.
ParamTypes
Enumeration
NameValueDescription
T_UNKNOWN0Undefined type. Generally an error
T_INTEGER1Standard long integer number
T_FLOAT2Single precision floating-point number
T_STRING4Character string value
T_BOOL8Boolean value
T_TRANSFORM16Transformation value, consisting of a matrix and a vector. Equivalent to 12-element single-precision floating-point array
T_MATRIX32Matrix value. Equivalent to 9-element single-precision floating-point array
T_VECTOR64Vector value. Equivalent to 3-element single-precision floating-point array
T_COLOR128RGB float color value. Equivalent to 3-element single-precision floating-point array
T_ACOLOR256RGBA float color value. Equivalent to 4-element single-precision floating-point array
T_LIST32768Binary OR-ed with the other type indicates that the value is a list of values of that type
RenderModes
Enumeration
Property NameValueDescription
RM_PRODUCTION0
Renders in production mode
RM_INTERACTIVE1
Renders in interactive mode
RM_CLOUD2
Starts the current render job on the Cloud
RM_LAST3Repeats the last render
RenderEngines
Enumeration
RE_CPU0
Renders on the CPU
RE_CUDA1
Renders on the GPU and/or CPU using CUDA
RE_RTX2
Renders on the GPU using RTX Optix
RhinoScriptComputeDeviceInfo
A structure packing all details for a GPU compute device into a single block
Property Name
Description
The name of the device
UseForRendering
Specifies whether the device is to be used for rendering or not
Name of the device
Syntax:
BSTR Name
Examples:
import rhVRay as vray
cudaDevices = vray.GetDeviceList(vray.RenderEngines.RE_CUDA)
name = cudaDevices[0].Name
import rh8VRay as vray
using VRayForRhino;
ComputeDeviceInfo[] cudaDevices = VRay.GetDeviceList(RenderEngines.CUDA).ToArray();
string name = cudaDevices[0].Name;
UseForRendering
Syntax:
VARIANT_BOOL UseForRendering
Examples:
use = cudaDevices[0].UseForRendering
using VRayForRhino;
bool use = cudaDevices[0].UseForRendering;
RhinoScriptSceneParam
Represents a reference to a NeUI plugin parameter
Property NameDescription
ValueGets or sets the value of the parameter. Must conform with the value type
TypeReturns the data type of the parameter. Can be OR-ed with ParamTypes::T_LIST
TypeAsStringReturns the data type of the parameter as a string
Value
Syntax:
VARIANT Value
Examples:
with vray.Scene.Transaction() as t:
    vray.Scene.SettingsOutput.img_width *= 2
using VRayForRhino;
using(Transaction t =  VRay.Scene.Transaction())
    Param img_width = VRay.Scene["SettingsOutput"].Param("img_width");
    img_width.Value = (int)img_width.Value * 2;
Type
Syntax:
ParamTypes Type
Examples:
paramType = vray.Scene.SettingsOutput.Param("img_width").Type
using VRayForRhino;
int paramType = VRay.Scene["SettingsOutput"].Param("img_width").Type
TypeAsString
Returns the data type of the parameter as string.
Syntax:
BSTR TypeAsString
Examples:
paramType = vray.Scene.SettingsOutput.Param("img_width").TypeAsString
using VRayForRhino;
string paramType = VRay.Scene["SettingsOutput"].Param("img_width").TypeAsString
RhinoScriptScenePlugin
ParamsReturns an array of references to all parameters for the current plugin
ParamNamesReturns an array of strings of all parameter names in the current plugin
NameReturns the name of the plugin
CategoryReturns the category of the plugin
TypeReturns the type of the plugin
Method NameDescription
ParamReturns a reference to a given plugin parameter
Params
Syntax:
VARIANT Params
Examples:
params = vray.Scene.SettingsOutput.Params
using VRayForRhino;
Param[] prms = VRay.Scene["SettingsOutput"].Params.ToArray();
ParamNames
Syntax:
VARIANR ParamNames
Examples:
paramName = vray.Scene.SettingsOutput.ParamNames
using VRayForRhino;
string[] paramNames = VRay.Scene["SettingsOutput"].ParamNames.ToArray();
Syntax:
BSTR Name
Examples:
pluginName = vray.Scene.SettingsOutput.Name
using VRayForRhino;
string pluginName = VRay.Scene["SettingsOutput"].Name;
Category
Syntax:
BSTR Category
Examples:
pluginCategory = vray.Scene.SettingsOutput.Category
using VRayForRhino;
string pluginCategory = VRay.Scene["SettingsOutput"].Category;
Type
Syntax:
BSTR Type
Examples:
pluginType = vray.Scene.SettingsOutput.Type
using VRayForRhino;
string pluginType = VRay.Scene["SettingsOutput"].Type;
Param
Syntax:
RhinoScriptSceneParam *Param(
[in, string] BSTR paramName
Parameters:
[in] BSTR paramName : Name of the parameter to getReturn:
Examples:
imgWidth = vray.Scene.SettingsOutput.Param("img_width")
using VRayForRhino;
Param imgWidth = VRay.Scene["SettingsOutput"].Param("img_width");
RhinoScriptScene
Represents the NeUI scene
PluginsReturns an array of references to all plugins in the scene
PluginNamesReturns an array of strings of all plugin names in the scene
PluginReturns a reference to a given scene plugin
PluginFromObjectReturns a reference to a plugin that is linked to an Rhino model object, given by ID
PluginsByTypeReturns an array of references to all plugins of a given type in the scene
PluginsByCategoryReturns an array of references to all plugins of a given category in the scene
RefreshRefreshes the NeUI window
MaterialsGets an array of all material plugins in the scene
LightsGets an array of all light plugins in the scene
SettingsGets an array of all settings plugins in the scene
SpecialObjectsGets an array of all special object plugins (proxies, clippers, furs and infinite planes) in the scene
LoadSettingsLoads a given .vropt file into the scene. The default file will be loaded on failure
SaveSettingsSaves the current settings into a given .vropt file
BeginChangeOpens a transaction to modify the scene. Call EndChange() when done modifying the scene
EndChangeCloses a scene modification transaction, previously opened by a call to BeginChange()
Plugins
Syntax:
VARIANT Plugins
Examples:
plugins = vray.Scene.Plugins
using VRayForRhino;
Plugin[] plugins = VRay.Scene.Plugins.ToArray();
PluginNames
Syntax:
VARIANT PluginNames
Examples:
plugins = vray.Scene.PluginNames
using VRayForRhino;
string[] pluginNames = VRay.Scene.PluginNames.ToArray();
Plugin
Syntax:
RhinoScriptScenePlugin* Plugin(
[in, string] const BSTR pluginName
Parameters:
[in] BSTR pluginName : Name of the plugin to get
Return:
Examples:
settingsOutput = vray.Scene.Plugin("/SettingsOutput"
settingsOutput = vray.Scene.Plugin("/SettingsOutput")
using VRayForRhino;
Plugin settingsOutput = vray.Scene.Plugin("/SettingsOutput");
PluginFromObject
Syntax:
VARIANT PluginFromObject(
[in, string] const BSTR id
Parameters:
[in] BSTR id : Rhino model object id to query
Return:
Examples:
vrayPlugin = vray.Scene.PluginFromObject("99dec31e-c736-4f7d-a98c-9dd321396344")
using VRayForRhino;
Plugin vrayPlugin = VRay.Scene.PluginFromObject("99dec31e-c736-4f7d-a98c-9dd321396344");
PluginsByType
Syntax:
VARIANT PluginsByType(
[in, string] const BSTR typeName
[in] VARIANT_BOOL onlyTopLevel
Parameters:
[in] BSTR typeName : Name of the plugins Type
[in] VARIANT_BOOL onlyTopLevel : VARIANT_TRUE to consider only top-level plugins, or all plugins otherwise. VARIANT_TRUE by default
Return:
VARIANT array of RhinoScriptScenePlugin
Examples:
vrayMtlAssets = vray.Scene.PluginsByType("MtlSingleBRDF", True)
vrayMtlAll = vray.Scene.PluginsByType("MtlSingleBRDF", False)
using VRayForRhino;
Plugin[] vrayMtlAssets = VRay.Scene.PluginsByType("MtlSingleBRDF", true).ToArray();
Plugin[] vrayMtlAll = VRay.Scene.PluginsByType("MtlSingleBRDF", false).ToArray();
PluginsByCategory
Syntax:
VARIANT PluginsByCategory(
[in, string] const BSTR categoryName
Parameters:
[in] BSTR categoryName : Name of the plugins type
Return:
Examples:
mtls = vray.Scene.PluginsByCategory("material", True)
all_mtl_plugins = vray.Scene.PluginsByCategory("material", False)
using VRayForRhino;
Plugin[] mtls = VRay.Scene.PluginsByCategory("material", true).ToArray();
Plugin[] all_mtl_plugins = VRay.Scene.PluginsByCategory("material", false).ToArray();
Refresh
Syntax:
void Refresh()
Examples:
vray.Scene.Refresh
vray.Scene.Refresh
using VRayForRhino;
VRay.Scene.Refresh();
Materials
Syntax:
VARIANT Materials()
Return:
Examples:
materials = vray.Scene.Materials
using VRayForRhino;
Plugin[] materials = VRay.Scene.Materials.ToArray();
Lights
Syntax:
VARIANT Lights()
Return:
Examples:
lights = vray.Scene.Lights
using VRayForRhino;
Plugin[] lights = VRay.Scene.Lights.ToArray();
Syntax:
VARIANT Settings()
Return:
Examples:
settings = vray.Scene.Settings
using VRayForRhino;
Plugin[] settings = VRay.Scene.Settings.ToArray();
SpecialObjects
Syntax:
VARIANT SpecialObjects()
Return:
Examples:
specialObj = vray.Scene.SpecialObjects
using VRayForRhino;
Plugin[] specialObj = VRay.Scene.SpecialObjects.ToArray();
LoadSettings
Syntax:
VARIANT_BOOL LoadSettings(
[in, string] const BSTR fileName
Parameters:
[in] BSTR fileName : Name of the file to load in
Return:
None-zero if succeeded, zero if failed
Examples:
success = vray.Scene.LoadSettings("Rhino Default.vropt")
using VRayForRhino;
bool success = VRay.Scene.LoadSettings("Rhino Default.vropt");
SaveSettings
Syntax:
VARIANT_BOOL SaveSettings(
Parameters:
[in] BSTR fileName : Name of the file to write out
Return:
Examples:
success = vray.Scene.SaveSettings("settings.vropt")
using VRayForRhino;
bool success = VRay.Scene.SaveSettings("settings.vropt");
BeginChange
Syntax:
void BeginChange()
Examples:
vray.Scene.BeginChange()
# scene modification statements
vray.Scene.EndChange()
# or in a RAII-manner
with vray.Scene.Transaction():
    # scene modification statements.
    # exiting the scope is equivalent to calling vray.Scene.EndChange()
using VRayForRhino;
VRay.Scene.BeginChange();
// scene modification statements
VRay.Scene.EndChange();
// or in a RAII-manner
using(Transaction tr = VRay.Scene.Transaction())
    // scene modification statements.
    // exiting the scope is equivalent to calling VRay.Scene.EndChange()
EndChange
Syntax:
void EndChange()
Examples:
#or in a RAII-manner
using VRayForRhino;
RhinoScriptObject
SceneReturns the currently active scene
VersionReturns the current plugin version
VRayVersionReturns the current V-Ray core version
Render
Starts a V-Ray render
CancelRenderStops the current rendering process
RefreshUI
Refreshes the NeUI asset manager window
GetDeviceListReturns the compute devices available on the machine for a given render mode
SetDeviceListSets a list of devices available on the machine, to be used for a given render mode
Scene
Syntax:
RhinoScriptScene* Scene
Examples:
scene = vray.Scene
scene = vray.Scene
using VRayForRhino;
Scene scene = VRay.Scene;
Version
Syntax:
int Version
Examples:
version = vray.Version
using VRayForRhino;
int version = VRay.Version;
VRayVersion
Syntax:
int VRayVersion
Examples:
vray_version = vray.VRayVersion
using VRayForRhino;
int vray_version = VRay.VRayVersion;
Render
Syntax:
void Render(
[in] RenderModes mode,
[in] RenderEngines engine,
[in] int timeout
Parameters:
[in] RenderModes mode: Specifies the mode the render job shall be executed in
[in] RenderEngines engine: Specifies the render engine to use for the current render job
[in] int timeout: Specifies whether the current render job shall be executed synchronously or asynchronously.
Use -1 for syncrhonous renders, and >=0 for specific wait timeout in milliseconds
Examples:
vray.Render(0, 0, -1)
using VRayForRhino;
VRay.Render(0, 0, -1);
CancelRender
Syntax:
void CancelRender()
Examples:
vray.CancelRender()
vray.CancelRender()
using VRayForRhino;
VRay.CancelRender();
RefreshUI
Syntax:
void RefreshUI(
Examples:
vray.RefreshUI()
vray.RefreshUI()
using VRayForRhino;
VRay.RefreshUI();
GetDeviceList
Syntax:
VARIANT GetDeviceList(RenderEngines engine)
Return:
VARIANT
Examples:
using VRayForRhino;
SetDeviceList
Syntax:
VARIANT_BOOL SetDeviceList(RenderEngines engine, VARIANT ids)
Return:
VARIANT_BOOL
Examples:
success = vray.SetDeviceList(vray.RenderEngines.RE_CUDA, [0, 1])
using VRayForRhino;
bool success = VRay.SetDeviceList(RenderEngines.CUDA, new int[]{ 0, 1 });
Render Quality
Changes the quality of the render from Low to High+.
Examples:
s = vray.Scene
with s.Transaction() as t:
  s.SettingsOptions.quality_preset = 4
s = vray.Scene
using VRayForRhino;
    VRay.Scene["SettingsOptions"].Param("quality_preset").Value = 4;
ValueDescription
0Low
1Low +
2Medium
3Medium +
4High
5High +
6Custom (uses the last used quality value)
Other values use the last selected quality value.
Render Engine
Sets Render Engine modes.
Examples:
s = vray.Scene
with s.Transaction():
s.SettingsOptions.render_mode=4
s = vray.Scene
using VRayForRhino;
    VRay.Scene["SettingsOptions"].Param("render_mode").Value = 4;
ValueDescription
-1RENDER_MODE_PRODUCTION
0RENDER_MODE_INTERACTIVE
4RENDER_MODE_INTERACTIVE_CUDA
7RENDER_MODE_INTERACTIVE_OPTIX
104RENDER_MODE_PRODUCTION_CUDA
107RENDER_MODE_PRODUCTION_OPTIX
Note that for versions prior to V-Ray 7, the script access manual is located at: C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\VRayForRhinoObjectModel.html
