This page provides information about the Material ID Number in V-Ray for SketchUp.
Material ID Number Render Element masks objects in the scene based on their shader Material ID Number value. The selection masks use automatic integer color assignment. The channel uses no anti-aliasing.
Opacity color and textures with values of 1 and 0 are supported by the Material ID Number channel.
This render channel is useful in a compositing process as a color mask for different materials in the scene.
Material ID Number
Beauty
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Material ID Number
||V-Ray Asset Editor|| > Create Asset (left-click) > Render Elements > Material ID Number
How to Set Material ID Number
From the Add Attribute button, add Material ID attribute. The new rollout contains ID Number and ID Color. After that, you can add the Material ID Number render element.
