This page provides information about the Sample Rate render element in V-Ray for SketchUp.
Displays the work being done by the image sampler as a red, green and blue image. A color is assigned to each pixel according to how many primary samples are being taken my the Image Sampler.
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Sample Rate
||V-Ray Asset Editor|| > Create Asset (left-click) > Render ElementsSample Rate
Denoise – Specifies whether to denoise this render element.
Bucket Image Sampler
The Sample Rate Render Element is useful for fine-tuning render settings using a "red is bad" rule.
Below is a scene with minimal red in the Sample Rate Render Element, indicating that the sampler had a high enough Max Subdivs value to hit the desired noise level.
Sampler
RGB
Render time = 11m 39s, Max Subdivs = 24, Noise Threshold = 0.01, Min shading rate = 6
The image sampler is mostly able to reach the noise threshold using the subdivisions allotted.
In the next image, the sampler did not have a high enough Max Subdivs value to hit the desired noise level. The high amount of red shows that the image sampler cut off sampling before the image hit the desired noise level. Noise can be decreased by increasing the Max Subdivs parameter to allow the image sampler to reach the desired noise level.
Sampler
RGB
Render time = 6m 17s, Max Subdivs = 8, Noise Threshold = 0.01, Min shading rate = 6
The Image sampler is mostly not able to reach the specified noise threshold.
The primary samples can be allocated to the complex areas of the image by increasing both the Max Subdivs and the Noise Threshold values. This way, V-Ray has enough available primary samples to lower the noise of the complex areas in exchange for an overall slight increase in noise, while still keeping the render times down.
Sampler
RGB
Render time = 5m 37s, Max Subdivs = 12, Noise Threshold = 0.02, Min shading rate = 6
Sample Rate Render Element with not enough Max Subdivs.
Alternatively, the image sampler can allocate primary and secondary samples by changing the Min shading rate value.
For this scene, increasing the Min shading rate allows the sampler more secondary samples to focus on cleaning the lighting, GI, reflections and refractions. In exchange, some of the detailed fur and high contrast areas are a bit noisier as there are not enough primary samples taken for those areas.
Sampler
RGB
Render time = 8m 38s, Max Subdivs = 8, Noise Threshold = 0.01, Min shading rate = 20
 Less primary samples are needed to hit the desired noise level, since more secondary samples are taken.
Progressive Image Sampler
The Progressive sampler uses the same algorithm as the Bucket sampler. The main difference is that the maximum samples increase as the sampler finishes each pass.
11 passes
Very few samples are given to complex areas of the image
36 passes
Samples start to focus on difficult areas.
200 passes
Many samples start to collect only when needed. White areas are the primary target now.
