width50%
Mode – This parameter allows you to select between different modes for extracting the data.
Fancy Bullets
typecircle
  • Primitive type
  • Mesh component
  • Material ID
  • Primitive ID
  • Instance ID (source mode)Pixel: World ratio
  • DUVW
  • Abs (DUVW)
  • Tangent
  • Material Type
  • Mesh componentPixel: World ratio
  • World position
  • Shading normal
  • Geometry normal
  • Dot product shading
  • Z-Depth
  • Backside hitTangent
  • Material ID
  • Primitive ID
  • Sub-primitive ID
  • Object Space Normal
  • Object Gradient
  • Wire colorColor
  • UVW
  • Circle of cunfusion
width5%
width45%
