Section | |||||||||||||||||||||||
UI Text Box | ||
Tips when working with progressive caustics: Required:
Optional:
Managing Expectations:
Anchor | ||||
Example: The Search Distance Parameter (Progressive)
For this example, the light used in the scene is V-Ray Sun. The Caustics Mode is set to Progressive. The V-Ray Sun has its Photon emission properties adjusted as so: Caustics Subdivs are set to 1500; the Caustics Multiplier is set to 2 and the Photon Radius is set to 30 cm.
Section | |||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
UI Expand | |||||||||||||||||||||||||||||||||||||||||||||
Example: The Search Distance Parameter (Photon Map)For this image, the light's Caustics Multiplier parameter (||Light|| > Advanced properties rollout > Caustics Multiplier) is set to 80 and the rest of the parameters are at their default values. As seen from the images, the larger Search Distance produces blurrier caustics.
Anchor | ||||
UI Expand | |||||||||||||||||||||||||||||||||||||||||||||||||||||
Example: The Max Photons ParameterIn this example the light's Caustics Multiplier parameter (||Light|| > Advanced properties rollout > Caustics Multiplier) is set to 80 and the rest of the parameters are at their default values. VRaySun is used in this scene. As can be seen, the larger value of the Max photons parameter causes the caustics to appear much smoother.
Anchor | ||||
Example: VRaySun Photon RadiusThis example shows how a light's photon radius affects the caustics effect. Here we use a VRaySun to light the scene. The Caustics Multiplier parameter in VRaySun's Advanced parameters rollout is set to 80 and the rest of the parameters are at their default values.
Progressive Caustics Advantages
Fancy Bullets | ||
Fancy Bullets | ||
