This page provides information on the standalone V-Ray Mesh Viewer.
Floatingpagetoc |
The V-Ray mesh viewer can be used to view both static as well as and animated meshes. Once you run it, the tool will ask asks you to navigate and point to the .vrmesh or .abc file you want to preview. Once you've located the file you want to view and click Open, You you will see the mesh.
You can navigate around the mesh by holding Alt and then using the Left mouse button to Rotate, the Middle mouse button to Pan, and the Right mouse button to Zoom.
The mesh viewer tool is installed along with V-Ray and can be found in the tools or bin folder with other external V-Ray tools. It can be launched directly from the executable file or from the Windows Start menu > All Programs > Chaos Group > V-Ray [for app.] > Tools > V-Ray mesh viewer.
Excerpt |
Menu CommandsFile menu Open – Allows you to load another .vrmesh or .abc file. Rendering Menu – The options here allow you to control how the mesh is previewed in the work area. Use mesh preview – Shows a simplified version of the mesh. The same preview is used inside the 3d Application. Colors Gray – The whole mesh is gray. |
a unique color. |
on the map channel it was unwrapped at. View Show Axis – Hides or shows the XYZ axis. General Options |
objects by their names. Selection Mode – Allows you to switch between selecting objects or voxels. Alembic Mesh OptionsThese options govern the displaying of alembic meshes. Subdivide all meshes – When enabled, all alembic meshes are |
subdivided. Subdiv level – Allows you to control the level of subdivision. Preserve geometry borders – When enabled, the subdivided geometry falls within the borders of the original mesh. Subdivide UVs – When enabled, the UVs of the object are also subdivided. Particle size – Allows you to control the preview size of particles. Animation OptionsThese options allow you to view different frames of the mesh when it is animated. You can use the |
timeline and drag the slider to move through the animation. Enter frame – Allows you to manually enter a frame number that you wish to preview. |
