This page provides information on the settings found in the V-Ray Settings window.
HideElements
cssselector#ehp-navigation-content, #easy-heading-free-end, #ehp-navigation-wrapper, #ehp-navigation, #ehp-nav-content-wrapper, #ehp-navigation-content, #ehp-navigation-switcher, .ehp-drag-bar, .ehp-navigation-title, .ehp-navigation-list, .ehp-navigation-bottom, #nav-header-wrap
CSS Stylesheet
#ehp-navigation-wrapper{ width: 0px !important; top: 0px !important; left: 0px !important; } #ehp-navigation{ width: 0px !important; } #ehp-navigation-content{ width: 0px !important; }
The V-Ray Render Settings can be accessed through the Settings button on the V-Ray for Revit Ribbon. Here you can find both global as well as project specific settings (such as render elements, infinite ground plane and atmospheric effects).
UI Path
||Revit Ribbon|| > V-Ray tab > Settings panel
Settings Tabs
The Settings window is organized under several tabs. Each tab hosts a different set of settings:
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
Textboxcard
PageToIncludeInstallation
CardPageLinkRenderer
Renderer
Specifies options for the render engine, GI, auto-save and optimizations.
Textboxcard
PageToIncludeGetting Started
CardPageLinkChannels
Channels
Render elements selector, including Denoiser, Z-Depth, Extra Texture, Lighting Analysis and Light Mix settings.
Textboxcard
CardPageLinkEnvironment
Environment
Contains options for atmospheric effects like aerial perspective and environment fog, as well as infinite ground plane settings.
Textboxcard
CardPageLinkPaths and Sharing
Paths & Sharing
Asset paths configuration, V-Ray Scene export options as well as V-Ray settings sharing options.
Textboxcard
CardPageLinkSwarm
Swarm
Controls V-Ray Swarm distributed rendering settings.
Textboxcard
CardPageLinkLicensing
Licensing
Contains licensing and usage statistics options.
Textboxcard
CardPageLinkView Specific
View Specific
Allows to modify some V-Ray parameters within the current view context.
Textboxcard
CardPageLinkConfig.json File Setup
Define a custom setup for some V-Ray and V-Ray Swarm settings.
