This page offers information about the Caustics Render Element in V-Ray for Cinema 4D.
width62%
Caustics is an effect that is produced when light rays are reflected or refracted by the materials within a scene, which can produce light patterns on objects in the scene. The Caustics Render Element displays these effects, generated with Caustics photon mapping. It is enabled from the Caustics rollout under the GI tab in the Render Settings window. This render element is useful for enhancing or toning down caustic effects in the composite.
UI Path: ||V-Ray|| > Render Elements > Caustics
width5%
width33%
Multiexcerpt include
MultiExcerptNameAddBackground
PageWithExcerptAtmospheric Effects RE
How to add a render element to a scene
width62%
Enable Deep OutputSpecifies whether to include this render element in deep images.
Color Mapping –  Applies the color mapping options specified in the Color mappingMapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
width5%
width33%
