This page provides information about the Refraction Filter Render Element in V-Ray for Cinema 4D.
width57%
The Refraction Filter Render Element is an image that stores refraction information calculated from the materials' refraction values refraction values in the scene.  Materials Materials with no refraction values appear as black, while completely refractive materials appear as white (maximum refraction) or gray (lesser amounts of refraction), and everything in between appears as a shade of gray. If any hue (color) is specified in the material's Refractive Color parameter, that hue and value will be are represented here in the Refraction Filter as well as being affected by the refraction's Amount parameter.
In comparison, the Raw the Raw Refraction Render Element is a color render element that takes materials and their colors into account when rendering refraction. Multiplying these two render elements together produces the Refraction Render Element.
UI Text Box
typenote
To properly calculate the Refraction Filter Render Element, the Refraction Render Element must also be added to the list of render elements being calculated during the rendering process to properly determine all the refraction information in the scene.
UI Path: ||V-Ray|| > Render Elements > Refraction Filter
width5%
width38%
Multiexcerpt include
MultiExcerptNameAddBackground
PageWithExcerptAtmospheric Effects RE
How to add a render element to a scene
width57%
Enable Deep OutputSpecifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mappingMapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
width5%
width38%
