Randomize by– Using this option, the occlusion can be controlled by a texture map or shader.
Primitives – When this mode is used, each of the items (color or textures) are randomly distributed on each mesh primitive (triangle). Material name – When this mode is used, the items (color or textures) are randomly applied to the different materials the Multi shader is assigned to. Objects – When this mode is used, each of the items (color or textures) are randomly distributed on each of the instances (objects). Material tag index – When this mode is used, each of the items (color or textures) are are randomly distributed based on the object’s material ID. Material ID – When this mode is used, each of the items (color or textures) are randomly distributed based on the material’s Buffer ID.
UI Text Box
type
note
Material IDs can be set via the advanced tab in each material.
Object buffer ID – When this mode is used, each of the items (color or textures) are distributed based on the object’s Buffer ID.
UI Text Box
type
note
Object Buffer's IDs can be set using the Corona Compositing tag for each object.
Mesh Element – When this mode is used, items (color or textures) are randomly distributed on all mesh elements (in case the mesh consists of multiple elements). Polygon – When this mode is used, items (color or textures) are randomly distributed on all mesh faces. (only available in Corona 8 and newer) Decal – When this mode is used, items (color or textures) are randomly distributed per decal object. (only available in Corona 8 and newer) Tile ID– When this mode is used, items (color or textures) are randomly distributed on object. Multiple properties – This option allows you to randomize the result by combining different modes.
Batch load textures – This option allows you to load multiple texture maps at the same time.
Layer count – This value defines the number of elements (layers) that are randomized.
Mix amount – This value controls the blending of all elements (layers). A value of 100% completely blends all element's colors or textures.
Seed – This value creates different randomizations.
Hue random – This value randomizes the Hue for each element (layer).
Saturation random – This value randomizes the Saturation for each element (layer).
Gamma random – This value randomizes the Gamma for each element (layer).
width
5%
width
45%
width
1%
width
48%
Image slider
Corona Multi Shader: Randomize by
Panel
title
Randomized by = Objects
Panel
title
Randomized by = Mesh elements
Panel
title
Randomized by = Polygons
width
2%
width
48%
Image slider
Corona Multi Shader: Mix amount
Panel
title
Mix amount = 0%
Panel
title
Mix amount = 50%
Panel
title
Mix amount = 100%
width
1%
width
1%
width
32%
Image slider
Corona Multi Shader: Hue random
Panel
title
Hue random = 0%
Panel
title
Hue random = 50%
Panel
title
Hue random = 100%
width
1%
width
32%
Image slider
Corona Multi Shader: Saturation random
Panel
title
Saturation random = 0%
Panel
title
Saturation random = 50%
Panel
title
Saturation random = 100%
width
1%
width
32%
Image slider
Corona Multi Shader: Gamma random
Panel
title
Gamma random = 0%
Panel
title
Gamma random = 15%
Panel
title
Gamma random = 30%
width
50%
Color – This is the color for each element (layer).
Frequency – This value controls the probability (frequency) of appearance for each element (layer).
Texture – This slot allows you to use a texture map or shader for each element (layer). If a texture map or shader is loaded, it overrides the element's color.
UI Text Box
type
tip
It's possible to capture any specific color even from an open image file by using the eye dropper tool that is right next to the color slot.
width
5%
width
45%
width
1%
width
32%
Image slider
Corona Multi Shader: Color
Panel
title
Color = Default color scheme
UI Expand
title
Click here to see the shader setup.
Panel
title
Color = Complementary colors
UI Expand
title
Panel
title
Color = 1 color + Hue, Sat, and Gamma randomization
UI Expand
title
width
1%
width
32%
Image slider
Corona Multi Shader: Frequency
Panel
title
Frequency = All set to 1
UI Expand
title
Panel
title
Frequency = 0.25 increments
UI Expand
title
Panel
title
Frequency = Random values
UI Expand
title
width
1%
width
32%
Image slider
Corona Multi Shader: Texture
Panel
title
Texture = 1 Color + 2 Textures
UI Expand
title
Panel
title
Texture = 4 Wood textures
UI Expand
title
Panel
title
Texture = 1 texture + Hue, Saturation, and Gamma randomization
