Responsivegridmacro | ||||||||||||||
Floatingpagetoc
Section | |||||||||||||||||||||||||||||||||||||||||
Selecting the V-Ray GPU Renderer
In order to use V-Ray, you must first select one of its renderers as your current renderer.
- Open the Render Setup window.
- At the top of the Render Setup window, choose Production Rendering Mode as the Target.
- For Renderer, choose V-Ray GPU.
UI Text Box | ||
Scenes saved with ActiveShade renderer (a previous GPU rendering workflow) should be switched to use V-Ray GPU as Production renderer instead. |
V-Ray GPU Render Settings Tabs
V-Ray GPU offers 4 different tabs in the Render Setup window.
Div | ||||||||||||||||||||||||||||
