width60%
The Perf. tab of the Render Setup window contains all performance related settings for V-Ray GPU. You can control the Utilization and Textures settings, or choose which devices to be included in the rendering and also set up Distributed Rendering.
UI Path: ||Render Setup window|| > Performance tab (Renderer set to V-Ray GPU)
width5%
width35%
Image Modified
Rollouts
The Performance tab consists of four rollouts:
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkGPU Utilization
Utilization rollout
Adjust parameters concerning shoot rays during rendering (both production and IPR rendering).
Textboxcard
CardPageLinkGPU Textures
Textures rollout
Controls size and resolution of textures with V-Ray GPU rendering.
Textboxcard
PageToIncludeInstallation
CardPageLinkGPU Distributed Rendering
Distributed Rendering rollout
Set Distributed Rendering settings.
Textboxcard
PageToIncludeGetting Started
CardPageLinkV-Ray GPU Render Devices Select
Easy access to a list of devices to include/ exclude from the rendering process.
