This page provides detailed information on Viewport Rendering in V-Ray.
Section | ||
Column | | |
UI Paths
Section | ||||||||||||||||||||||||||
Workflow
Expand | ||
Viewport Rendering In Previous SketchUp Versions |
UI Paths
Viewport Rendering
Viewport Rendering in SketchUp 2023
Column | ||
width | 25% |
SketchUp Menus Ribbon
||Extensions|| > V-Ray > Rendering > Render Interactive
||V-Ray for SketchUp Toolbar|| > Render Interactive
||V-Ray Frame Buffer|| > Start Interactive Rendering
||V-Ray Frame Buffer|| > Region render
Column | ||
Column | ||
||Window|| > Default Tray > Overlays > V-Ray Viewport Render
||Extensions|| > V-Ray > Preferences > Viewport Render Opacity |
Column | ||
Workflow
To start the Viewport render, activate the V-Ray Viewport Render Overlay first. Then start an Interactive render. Adjusting the viewport render region is available with the V-Ray Frame Buffer Region render option. The Viewport Render Overlay opacity is modified from the Viewport Render Opacity menu option.
Fancy Bullets | ||
