width65%
V-Ray Renderer is the main V-Ray component. It builds the scene and initiates the render rendering process. Right-click to Start or Stop the render process or to show the V-Ray Frame Buffer window.
Note that if you closed close or minimized minimize the V-Ray Frame Buffer window while rendering, you can restore it via the Show Frame Buffer option.
width10%
width25%
width60%
Scene(Generic Data)– This is the V-Ray scene output. It can be connected to a V-Ray Exporter component in order to export the scene to a disk or V-Ray Render in Project component to transfer all scene data to Rhino.
UI Text Box
typeinfo
Chaos Cloud is now integrated within V-Ray for Grasshopper. Right-click the V-Ray Render component to find the new option Render on the Cloud action. Note that having a Timeline component connected always exports an animation.
Context Menu
Right-click on the V-Ray Render component to open.
Render – Starts the rendering process.
Render Animation – Renders animation.
Render on the Cloud – Automatically exports a .vrscene and submits it to Chaos Cloud for rendering. Note that animations are always included when present.
Stop –  Stops the rendering process.
Show Frame Buffer – Shows the V-Ray Frame Buffer.
Use default light –Adds a directional light with default parameter values if no other light exists in the scene.
width10%
width25%
Image RemovedRhino8_VRay6.2_RenderComponents_Render_ContextMenuImage Added
Right-click on the component to see more options.
