This page provides information about the Input tab of the V-Ray Volumetric Grid.
The Input rollout The Input rollout determines the path of the input files for rendering and preview as well as and the playback effects. Note that some playback settings require a fractional input frame, in which case the frame is blended between the previous and the next one.
UI Text Box
typenote
Field3D files which that come from FumeFX must be exported with gzip compression! If they are exported with the default proprietary FumeFX compression, they will not be imported properly in the V-Ray Volume Grid.
Input
width
52%
Volume Type – Determines what file type the Volume Grid is reading. The File Type supports the following cache files: Phoenix FD *.aur, Field3D *.f3d, and OpenVDB *.vdb. The VDB Generator allows Pyro Output objects to be linked to the Volume Grid, replicating the simulation while allowing the parameters of the Pyro simulation to still be editable.
Input Cache File – Gives the directory and the name template for the input files.
Click the "..."
to open a dialog for choosing one of several cache file types.
VDB Generator – Links a Pyro Output object to the Volume Grid. Drag and drop onto the field, or use the eyedropper tool. After linking the object, use the c4d2024_dropdownArrow.pngImage Added button to expand the Pyro's parameters, and you can further edit them there or directly inside the Pyro Output and the Pyro tag. Changes are reflected everywhere. The Pyro Output object needs to be located in the current scene. NOTE: For the best results, when using the VDB Generator Volume Type, we recommend the Volume Grid's Render Mode be set to Volumetric
width5%
width38%
 PNG File c4d2024_61030_VolumeGrid_Input_CacheFile1.pngImage Added
File Type
c4d2024_61030_VolumeGrid_Input_VDBGenerator.pngImage Added
VDB Generator Type
UI Expand
titleClick Here to expand additional $(VARIABLE) and Channel Mapping information
$(work_path) – $(data_dir)/$(scene)_Phoenix_frames/$(nodename)_####.aur
$(data_path) – $(data_dir)/$(scene)_Phoenix2_frames/$(nodename)_####.aur
$(scene_path) – $(dir)/$(scene)_Phoenix_frames/$(nodename)_####.aur
$(scene_dir) – $(dir)/$(scene)_Phoenix2_frames/$(nodename)_####.aur
$(implicit) – Same as $(data_path).
$(dir) – The scene directory.
$(data_dir) – The current workspace data directory.
$(scene) – The scene file name.
$(nodename) – The name of the node.
$(fullname) – The full name of the node.
$(workspace) – The current workspace directory.
$env(<variable_name>) – An environment variable. See more about environment variables
If you are transferring your scene and assets between Windows and Linux, prefixing your path with the $(workspace) or $env(<variable_name>) macros can make it possible to use the same scene without any manual modifications to the cache path.
Pound signs (i.e., hash) can be used to specify the cache frame number with at least as many digits as the pound signs. If the number of frame digits is less than the number of pound signs, the number is padded with zeroes to the left. For example:
Align
aligncenter
Result
Frame Number#######
11010001
1010100010
1000100010001000
UI Text Box
typetip
You can suppress the showing of the dialogues offering presets using the inDontOfferPresets attribute of the Volume Grid. E.g. "setAttr VRayVolumeGrid1.inDontOfferPresets 1".
Time Bend Controls
width52%
The
This following parameters contains contain playback options you can use for retiming a cached sequence. Using these, you can speed up, slow down, or animate the motion of the sequence. When retiming, additional RAM may be used, and loading a new timeline frame may take longer when the frame must be obtained by creating a new one between two adjacent cache files. We will refer to the process of creating an intermediate frame from two caches as as Blending
Playback Mode – Chooses between different options for animation control:
Linear – This is the default mode. The cached sequence is played with a constant speed and can be offset forward or backward on the timeline, as well as sped up or slowed down.
Cache Index – The Direct Cache Index specifies specifies which cache file will be loaded for the current timeline frame. Can be used to either show a static simulationstatic simulation, or the Direct Cache Index can be animated in case you want varying play speed, including playing the simulation in reverse.
Loop – A specified piece of the simulated sequence is looped. Can be used for flowing and repeated effects such as fireplaces, campfires or torch fires, water in fountains, waterfalls, or boiling liquid. In this mode, the Cache Origin parameter specifies the beginning of the looped sequence, the Length parameter specifies the length of the loop, and Loop Overlap specifies the number of overlapped frames that ensure a smooth transition between the end and the start of the loop. Note that you need to have simulated at least Cache Origin Length + Loop Overlap cached frames for this mode to work correctly.
Direct Cache Index – Used in Cache Index mode and specifies the cache file index for the current timeline frame. This can be animated in order to achieve more interesting time-bend effects.
Cache Origin – An offset specifying which cache file from the sequence is placed on the timeline at frame Timeline Origin.
Timeline Origin – An offset specifying which timeline frame the starting cache is placed on.
Play Speed – A multiplier for the playback speed. Value A value of 1 means that each timeline frame corresponds exactly to one cache file index. If the play speed Play Speed is not exactly 1.0, frames are blended between by using the method specified by the the Blend Method parameter. Note that Play Speed is not keyable - you should switch to Cache Index mode and animate the Direct Cache Index if you want to animate.
Play Length – The duration in timeline frames. In Linear mode, when this parameter is larger than 0, the sequence length is limited to its value. In Loop mode, this parameter shows the loop length.
Loop Overlap – In Loop mode mode, this option specifies the number of timeline frames after the loop's end that are blended with the loop's beginning to create a smooth transition.  Keep in mind Remember that the end transition frames are not in front of the sequence end but after it. For example, if the loop starts at frame 35 and has a Play Length of 20 and a Loop Overlap of 5, the transition frames start at frame 55 and end at frame 59, which means the simulation must be at least 59 frames long. It is recommended that the Loop Overlap value be longer than the average "lifetime" of the simulation elements while involved in highly visible motion.  For example, for a waterfall, the Loop Overlap value value should be at least the average time it takes for a water droplet to fall the full distance before being absorbed into the water at the bottom. For a campfire, it should be at least the average time for a particle to rise up and disappear/die.  Correct The correct setting of this value is especially important for simulations that contain particles.
Grid Blend – Used when the Play Speed parameter is not exactly 1.0, or the Direct Cache Index for the current timeline frame is fractional, or you have specified a Loop Overlap in Loop mode. In these cases, a single timeline frame must be constructed from two cache files by blending between them. Each time the timeline is scrolled to a new frame, the caches for this frame are blended again. You can choose between three different methods for blending between cache files:
Interpolation – Simple linear interpolation suitable for slow simulations. This is the fastest method, but it does not capture movement well and may produce flickering.
Velocity – Velocity-based interpolation. Produces better results , but is also slower. Captures the movement of the fronts of the plumes well , but does not work well for smoke moving backward, and also may produce flickering. It requires a velocity channel.
Precise Tracing – Improved Velocity-based interpolation for Fire and Smoke simulations. Captures plume movement very well and can handle very low Play Speeds. Requires a Velocity channel, as well as an Advection Origin channel.
UI Text Box
typetip
Frame Blending is better suited for simulations without much variety in velocity.
Load Nearest If Missing – If there is no cache file at the required frame, the nearest cache is found and loaded. This is useful for a simulation that ends with a sequence of static frames (for example, still liquid or freezing fire) as it prevents the need to render multiple identical frames after movement has stopped.
Flip Up Axis – When enabled, flips the Y and Z axis of the cached transformation. This is useful when the cache was created with a different up-axis (for example, in 3ds Max).
UI Text Box
typenote
Smoothing is performed after the cache file is loaded for the current frame, so for large grids it could cause significant lag after changing frames.
The following controls allow you to smooth the grid channels loaded from cache files for preview and rendering. You can use this to prevent grid artifacts on meshed grid channels such as the Liquid surface, Smoke or Temperature, to remove unwanted noise in these channels, or to get smooth motion blur by smoothing the Velocity grid channel.
Smooth Threshold – If this value is 0, the entire grid is smoothed evenly. The higher the threshold is raised, the fewer voxels are affected and only the sharpest gradients are smoothed. The highest value you could use here depends on the range of the values of the smoothed channel – for Smoke it's usually in the [0,1] range, while for Velocity it could go as high as several hundred and for Temperature it could be over a thousand. If you set this value too high, no voxels are smoothed at all.
Smooth Similarity – Increasing this value allows you to smooth only the finer small-scale noise without changing the areas of the fluid which are already smooth. Note that just like the Threshold option, this value also depends on the range of the selected channel. If you want to remove only some sharp fine disturbances from the simulation without blurring other areas, set the Threshold to 0, increase the Similarity to the highest values the selected channel can take and then start reducing it until the small-scale noise is removed, while the larger fluid shapes are retained. This option won't take effect if the Threshold parameter is raised to the maximum.
Smooth Randomization – This parameter introduces noise of uniform scale in the channel before smoothing is applied. This can be useful if you want to give the fluid a more homogeneous pattern and this way it can also help hide grid artifacts. Note that just like the Threshold option, this value also depends on the range of the selected channel. You can use this option to add only noise to the channel without smoothing it – in order to do this, set both Threshold and Similarity to the highest values of the selected channel and this way they do not take effect.
width5%
width33%
Image Removed
Mirror Z Axis – When loading cache from a Pyro simulation or cache exported from Maya, enable this option and disable the Flip Up Axis option to load the cache correctly. When both Mirror Z Axis and Flip Up Axis options are enabled, the cache exported from 3ds Max is loaded correctly.
width5%
width38%
c4d2024_61030_VolumeGrid_TimeBend.pngImage Added
Example: Timeline Origin
width50%
UI Text Box
typeinfo
The following example demonstrates how the Timeline Origin parameter can be used to specify which frame on the timeline is treated as the first frame when reading the Input Path cache files.
The files go from simulationFrame_000 to simulationFrame_030. When the Timeline Origin is set to 10, they are read as if they were saved as simulationFrame_010 to simulationFrame_040.
width5%
width45%
PHX_TimelineOrigin.jpgImage Modified
Example: Cache Origin and Play Speed
width50%
UI Text Box
typeinfo
The following example demonstrates how the Cache Origin and Play Speed options can be used to offset and speed up the input cache files.
The files go from simulationFrame_000 to simulationFrame_030. When the Timeline Origin is set to 100, they are read as if they were saved as simulationFrame_100 to simulationFrame_130.
The Cache Origin parameter is then used to specify which simulationFrame will be is placed on Timeline Origin = 100. Because Cache Origin is set to 10, the whole sequence is shifted 10 frames back such that simulationFrame_000 is placed at frame 90. Thus, the sequence now goes from frame 90 to frame 120.
The Play Speed is then set to 2.0. Those thirty frames are now reduced to fifteen. The Cache Origin frame is treated as the middle point when shrinking the sequence.
width5%
width45%
PHX_TimelineOrigin_CacheOrigin.jpgImage Modified
Example: Looping a Simulation
width50%
UI Text Box
typeinfo
The following example demonstrates how the Input roll-out parameters can be used to loop a simulation.
The Timeline Origin parameter is set to 0 - this will be the first frame of the timeline on which the Input Path files read into the scene by the Simulator will be placed on.
The Cache Origin is set to 10, so simulationFrame_010 will be read and placed at Timeline Origin = 0.
The Play Length is set to 15, so the sequence now repeats itself every 15 frames when played back (those are actually simulationFrame_010 to simulationFrame_025).
Finally, the Loop Overlap parameter is set to 5 to provide a few extra frames for blending the start and end of the loop together in a smooth transition.
width5%
width45%
PHX_LoopScheme.jpgImage Modified
Example: Play Speed
UI Expand
titleExample: Large Smoke (Play Speed: 0.1)
width1%
width98%
Align
aligncenter
HTML
<iframe width="720" height="405" src="https://www.youtube.com/embed/CJYmkNn21Fo" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
width1%
UI Expand
titleExample: Gasoline Explosion (Play Speed: 0.1)
width1%
width98%
Align
aligncenter
HTML
<iframe width="720" height="405" src="https://www.youtube.com/embed/KU60XwSafUY" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
width1%
UI Expand
titleExample: Burning Fuel (Play Speed: 0.1)
width1%
width98%
Align
aligncenter
HTML
<iframe width="720" height="405" src="https://www.youtube.com/embed/yI5I2rDxlNs" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
width1%
Anchor
environmentVariables
Using Environment Variables with Volume Grid Paths
There are path environment variables in every OS, and they can be used with Volume Grid cache file paths.
For example, to access environment variables in Windows 10 and Windows 8, follow these steps:
  1. In Search, search for and then select System (Control Panel).
  2. Click the Advanced system settings link.
  3. Click the Environment Variables... button.
  4. In the System variables section section, using using the Edit System Variable (or New System Variable) window, specify the value of the PATH environment variable.
Using this, you can create a path (variable), give it a name, and use it for cache files in the V-Ray Volume Grid.
For example, the path D:\V-Ray\Cache can be given the environment variable name "Cache". In the Volume Grid Input rollout, you can specify the path as the following:
$env(Cache)\cache_name###.aur
This will load the  the cache files in in D:\V-Ray\Cache.
Note that in order to reference environment variables, the following pattern must be used:
