width55%
Particle Type – Determines whether V-Ray particles, Phoenix particles, or Geometry Instances are used.
Particle Source – Specifies which emitter in the scene is used as a particle source. Supported sources are X-Particles Emitter, Thinking Particles Groups, MoGraph Matrix and Cloner objects, and Cinema 4D Emitter object.
Panel
borderColorlightblue
borderStylesolid
Jump to the appropriate Particle Type page:
UI Button
colorred
icontext
titleV-Ray Particle Type
urlhttps://docs.chaos.com/display/VC4D4EDITVC4D/V-Ray+Particle+Type
UI Button
colorred
icontext
titlePhoenix Particle Type
urlhttps://docs.chaos.com/display/VC4D4EDITVC4D/Phoenix+Particle+Type
UI Button
colorturquoise
icontext
titleGeometry Instances Particle Type
urlhttps://docs.chaos.com/display/VC4D4EDITVC4D/Geometry+Instances+Particle+Type
width5%
width40%
