width55%
Here are the main components of the Lister. They are available for all tabs:
Filters – Filters the objects by Groups, Layers, and Selection sets.
Search bar – Searches for an object. You need to enter at least 3 symbols in the field. If a filter is applied, it searches only from the stack with the filtered objects.
Options – Offers options for loading, saving and resetting layouts.
Loads Layout – Opens the Choose settings file to load window and loads a .vrlst layout file.
Save Layout – Opens the Choose saved file destination window and saves the current settings as a layout preset in a .vrlst format.
Reset Layout – Resets the layout to its default state.
Display options – Opens the Display options dialog where you can add or remove columns and cellsshown parameters.
UI Text Box
typenote
Note that some of the additional columns contain settings that should not be modified as the modifications would have no effect. However, V-Ray provides access to them and you can check their default values.
Titlebar – All cells except for the first 4 cells can be rearranged. The first 4 cells are always going to stay in the same order. The Name cell is stretchable, while the rest of the cells are not.
Statistics for selection – Shows the number of selected objects.
Deselect – Deselects all objects.
UI Text Box
typetip
The number of instanced lights or cameras is marked in brackets in front of the object’s name.
UI Text Box
typetip
Note that the Lights and Cameras tabs can be rearranged by dragging them.
width5%
width40%
Click on the image to enlarge it.
width55%
The Lights tab controls common parameters for all lights in the scene.
Lights can be enabled or disabled from the Enable checkbox.
In the Light tab, instanced lights appear as a single entry with a dropdown. Editing any parameters for the entry affects all instances. The dropdown can be used to select a specific instance in the viewport.
For more information on the parameters displayed for V-Ray lights in the Lister, see the respective page for the specific light type.
width5%
width40%
Cameras Tab
width55%
The Cameras tab controls common parameters for all cameras in the scene.
The Look thoughthrough () icon sets the active viewport to look through the specified camera.
For more information on the parameters displayed for V-Ray Physical Camera in the Lister, see the VRayPhysicalCamera page.
UI Text Box
typenote
Note that changes done to the parameters in the Camera tab cannot be undone from the Edit > Undo menu.
width5%
width40%
