Section | ||||||||||||||||||||||
Object
Config
Section | ||||||||||||||||||||||||||||||||
Camera clipping
Surface Scattering
Anchor |
Example: Slope
The Slope effect removes scattered objects depending on the angle of the underlying geometry. Slope can be used to remove objects from steep areas, as well as shallow areas, using the From and To parameters.
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Slope Up mode
The Local Up mode takes the normals of the Distribute On object and uses them to determine which way is up. In this example, the Slope is set From 0° To 45°.
Before after | ||||||||||
Consider collapsing the Table of Contents to view these examples in a larger size.
Anchor | ||||
Example: Altitude
Transformations
Areas
Viewport Display
