This is the documentation home page for V-Ray Benchmark.
Floatingpagetoc |
UI Button | ||||||||||
What is V-Ray Benchmark
V-Ray Benchmark is an application that tests your system resources to measure how well your system renders V-Ray scenes using both the CPU and the GPU(s). Through a standalone executable, users can run V-Ray Benchmark to see how well their system performs rendering sample scenes for a fixed amount of time without having V-Ray installed. There are two ways of benchmarking your machine - using the dedicated GUI application, or alternatively through the command-line interface.
Fancy Bullets | ||
UI Text Box | ||
GPU Rendering A hardware device with at least 2048 MB of VRAM is required for benchmarking your GPU. NVIDIA driver version 410.48 or newer is required. GPU devices will not be available for benchmarking unless these requirements are fulfilled. |
Where to Download
Click the link below to download V-Ray Benchmark. Once you log in to your account, you can download V-Ray Benchmark for the desired operating system as an executable file that may be placed anywhere on your machine to be run directly. There is no licensing or installation required, but please do read through the license agreement once you launch the application.
Section | |||||||||||||||||||||||||||||||||||||||
