This page provides details on the Lens Effects tools available in V-Ray for Unreal.
Floatingpagetoc |
Section | ||||||||||||||||||||||
UI Path
Result Channel
Bloom/Glare Parameters
Anchor | ||||
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Anchor | ||||
Example: Intensity
Anchor | ||||
Example: Cold/Warm & Saturation
Aperture Shape
Anchor | ||||
Example: Streak blur
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Lens Scratches
Lens Dust
Obstacle Image
Anchor | ||||
Example: Obstacle Images
Size (constant) = 50
Bloom (constant) = 0.5
Aperture Preview
File Names of Saved Channels
However, using the Save separate render channels option from the Frame buffer rollout to save all layers as separate files will save the effectsResult channel to a file with the text RGB_color appended to its name, and the RGB channel as origRGB instead.
