This page gives information about the Chaos Cosmos Browser in Houdini.
Section | |||||||||||||||||||
Usage
Usage
Section | |||||
Download Assets
Section | |||||
Import Assets
Section | |||||
UI Text Box | ||
Assets: Note that the Cosmos geometry is imported as V-Ray Proxy. You can refer to the V-Ray Proxy page for additional information. Any material in the scene can be used to override the shader and allows for quick customizations of the scene. You can find the newest assets in the Recently added section of the Cosmos browser. |
UI Text Box | ||
HDRI: The HDRI assets create a Dome Light with the hdri file attached to it. It is recommended to use VRayPhysicalCamera when using Cosmos hdri files for lighting. Alternatively, you can lower the dome light intensity. |
Update Assets
Enmesh Support
Example
This example shows a scene without and the same scene using Chaos Cosmos assets.
