UI Text Box
typetip
 UI Path: ||Select Liquid Simulator|| > Modify panel > Simulation Speed rollout
Actions
width50%
Expand – Opens a floating dialog that contains the selected rollout and automatically folds the command panel rollout.
Re-Center – Resets the position of the floating rollout.
? – Opens up the help documents for the Liquid Simulation Speed rollout.
UI Text Box
typeinfo
The Simulation Speed rollout shows a breakdown of the phases of your simulation, highlighting those that are taking the longest to complete. For each phase identified, advice is given on how to optimize it.
width5%
width45%
Image Modified
