This page provides information about the V-Ray Object Properties in V-Ray for Cinema 4D.
In addition to the options in the Render Settings, which are global for the scene, you can set different render settings on a per-object basis. Some of those properties (primary and secondary visibility, visibility to camera etc.) are accessible through the Object Properties tag.
If you wish to learn how to create a Shadow Catcher object using VRayObjectProperties, see the How to Use Matte Objects tutorial.
Section | |||||||||||||||||||||||||||||
UI Text Box | ||
Starting with Cinema 4D 2023.1, the Object Properties tag resides in Extensions > V-Ray tags. |
General
Matte Properties
Surface Properties
Visibility Options
Include/Exclude
