width55%
Here are the main components of the Lister. They are available for all tabs:
Filters – Filters the objects by Groups, Layers, and Selection sets.
Search bar – Searches for an object. You need to enter at least 3 symbols in the field. If a filter is applied, it searches only from the stack with the filtered objects.
Options – Offers options for loading, saving and resetting layouts.
Loads Layout – Opens the Choose settings file to load window and loads a .vrlst layout file. See more information in the Default and Custom Layouts section.
Save Layout – Opens the Choose saved file destination window and saves the current settings as a layout preset in a .vrlst format.
Reset Layout – Resets the layout to its default state.
Display options – Opens the Display options dialog where you can add or remove shown parameters.
UI Text Box
typenote
Note that some of the additional columns contain settings that should not be modified as the modifications would have no effect. However, V-Ray provides access to them and you can check their default values.
Titlebar – All cells except for the first 4 cells can be rearranged. The first 4 cells are always going to stay in the same order. The Name cell is stretchable, while the rest of the cells are not.
Statistics for selection – Shows the number of selected objects.
Deselect – Deselects all objects.
UI Text Box
typetip
The number of instanced lights or cameras is marked in brackets in front of the object’s name.
UI Text Box
typetip
Note that the Lights and Cameras tabs can be rearranged by dragging them.
width5%
width40%
Click on the image to enlarge it.
width55%
The following options are available for all tabs:
– Indicates that the light or camera is visible.
– Indicates that the light or camera is invisible.
– Indicates a combination of visible and invisible lights/cameras under the same row of instances.
UI Text Box
typetip
Press Ctrl and click the Visibility ()icon of an object to make a multiple selection.
width5%
width40%
Anchor
LoadLayouts
LoadLayouts
width100%
To correctly load .vrlst layout in the VRayLister, follow these steps:
Fancy Bullets
typecircle
  • Create a layout preset in the VRayLister by dragging columns and/or tweaking the Display options.
  • Close the VRayLister. Thus, V-Ray saves the layout locally.
The layout is stored in the vraylisteruser.vrlst file, which is located in: C:\Users\%user%\AppData\Local\Autodesk\3dsMax\20## - 64bit\ENU\en-US\plugcfg where ## stands for the version of 3ds Max used.
Now, every time you open a new scene, the .vrlst file in the ENU folder will be loaded automatically.
When creating the layout, you can also store it in a location or network of your choice before closing the VRayLister from Options button > Save layout. Thus, you have a backup file of the layout.
You can save as many layout presets as you want.
To load another .vrslt layout:
  • Reopen the VRayLister, and then load the custom layout from the Options button > Load layout.
Тhe newly loaded layout will override the current one in the vraylisteruser.vrlst file.
Lights Tab
width55%
The Lights tab controls common parameters for all lights in the scene.
Lights can be enabled or disabled from the Enable checkbox.
In the Light tab, instanced lights appear as a single entry with a dropdown. Editing any parameters for the entry affects all instances. The dropdown can be used to select a specific instance in the viewport.
For more information on the parameters displayed for V-Ray lights in the Lister, see the respective page for the specific light type.
width5%
width40%
