UI Text Box | ||
For a list of supported Render Elements, please check the Render Elements page. You may also check the Volumetric Rendering In-Depth guide for tips on speeding up the rendering of volumetric effects with V-Ray. |
Section | ||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Step %
This example shows how the Step % value can be used to improve the quality of the ray-marching.
Example: Heat Haze
This example shows how Heat Haze adds refraction at each ray-marching step through the volume. This only affects the camera's view. Heat haze will not affect shadows cast through a volume.
Example: Volumetric Motion Blur for Fire
Example: Volumetric Motion Blur for Explosions
Surface
