This page provides some details on the settings available for the Fast SSS Material in V-Ray.
Section | |||||||||||||||||
UI Expand | ||||||||||||||||||||||||||||||||||||||||||||
General Parameters
Section | ||||||||||||||||||||||
Anchor | ||||
Example: Sub-Surface Color
This example and the next demonstrate the effect of and the relation between the Scatter color and the Sub-surface color parameters. Note how changing the Sub-surface color changes the overall appearance of the material, whereas changing the Scatter color only modifies the internal scattering component.
The Scatter color is set to beige.
Section | |||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Scatter Color
The Sub-surface color is white.
Anchor | ||||
Example: Scatter Coefficient
This example demonstrates the effect of and the relation between the Scatter Coefficient and the Fog color parameters when the Scatter Mode is set to Scatter Coefficient and Fog Color. The Fog color is set to white for all the images.
Anchor | ||||
Example: Fog Color
This example demonstrates how Fog Color works together with the Scatter Coefficient color. The Scatter Coefficient color is white for all the images.
Anchor | ||||
Example: Scatter Radius and Scale
This example shows the effect of the Scatter radius and Scale parameters. Note how increasing them allows the inside (Scatter coefficient) color to show up more and leads to a softer look.
Anchor | ||||
Example: Phase Function
This example shows the effect of the Phase function parameter. This parameter can be likened to the difference between diffuse reflection and glossy reflection on a surface. However, it controls the reflectance and transmittance of a volume. Its effect is quite subtle, and mainly related to the single scattering component of the material.
The red arrow represents a ray of light going through the volume; the black arrows represent possible scattering directions for the ray.
Anchor | ||||
Example: Phase Function: Light Source
This example demonstrates the effect of the Phase function parameter when there is a light source inside the volume. The material uses Color mode: Scatter coefficient and fog color, large Scatter radius and Single scatter: Raytraced (Refractive).
Specular Layer Parameters
Options
Anchor | ||||
In the second set of images, the Scatter radius is set to 50.0 cm. In this case, the material is quite transparent, and the difference between the different Single scatter modes is apparent. Note also the transparent shadows with the Raytraced (refractive) mode.
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||
Bump and Normal mapping
Anchor | ||||
