This page provides information on the USD import and export workflows in V-Ray for Maya.
UI Text Box
typenote
Starting with V-Ray 6, update 2 the default USD translator becomes Hydra compatible.
Import Workflow
width55%
USD files can be loaded in Maya and rendered with V-Ray using the MayaUSD plugin with mayaUsdProxy nodes.
We recommend following a standard workflow with MayaUSD when rendering with V-Ray. See the video for more.
Fancy Bullets
typecircle
  • In Maya, go to Create > Universal Scene Description (USD) > Stage From File...
  • Locate the desired USD file in the directory window.
  • Click on Create.
width5%
width40%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/3P8iUmzk2f0" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Importing V-Ray materials using USD files
UI Text Box
typeinfo
The standard workflow imports V-Ray materials as Maya materials.
UI Expand
titleClick here for UI example
width30%
width40%
width30%
Importing V-Ray Physical Cameras using USD files
UI Text Box
typenote
If you are using a zip-installed V-Ray 5, update 2, for Maya or newer, make sure to set up the PXR_PLUGINPATH_NAME environment variable. Otherwise, exporting and importing V-Ray Physical Cameras is impossible. For more information on setting up environment variables, please visit the Installation from zip page.
Export Workflow
info
width55%
Fancy Bullets
typecircle
Exporting V-Ray shaders to USD versions up to 0.13.0 including:
from File > Export All... or Export Selection... (select the Option box) > General Options and as File Type, select USD Export. Under File Type Specific Options > Geometry, set the Materials to V-Ray MaterialExporter.
UI Text Box
type
When using USD 0.15.0 or below, if V-Ray is not selected as Plug-
  • In
Configuration, but For USD version 0.15.0 or higher:
in the
  • the
V-Ray Materials option is enabled, the export fails with an error. If V-Ray is selected as a Plug-In Configuration, but the V-Ray Material option is disabled, the exported USD does not contain the V-Ray materials.
  • File > Export All
Options
  • Optionswindow, set the File Type to USD Export
  • and choose whether the materials are
to be
  • exported as USD Preview Surface or as V-Ray materials. You can export all materials in the scene as one or multiple types of networks.
    • Alternatively, you can use
the Export Materials to USD option in
    • the V-Ray menu's Export Materials to USD option.
    • For more information, please visit
the
ui-
expand
titleClick to expand for Export Options screenshots...
width10%
width35%
Image Removed
For USD versions up to 0.13.0
width10%
width35%
Image Removed
For USD version 0.15.0 or later
width10%
ui-
text-box
typetip
Exporting lights to USD does not require the V-Ray Material Exporter to be selected in the Export to USD menu.
Disable the Merge Transform and Shape Nodes option from the Advanced rollout for a cleaner hierarchy, export, and correct rendering of VRaySubdivisions.
width5%
width40%
Image Added
Working with Multiple UVs
Starting with V-Ray 6, update 2 the default USD translator is Hydra compatible.
Export and import of multiple UVs is supported under the following condition: digits are forbidden as first characters in the name of the UVset.
To ensure proper workflow with UV sets the export Plug-in configuration should be set to V-Ray. Otherwise, they are exported with Maya's convention.
Should unexpected errors occur using older assets, it is recommended to re-export the UVset.
