V-Ray for Houdini
V-Ray for Houdini Help
Solaris
Solaris Features and Limitations
Old Version
13
changes.mady.by.user
Gergana Lilkova
Saved on
Feb 16, 2024
compared with
New Version
14
Gergana Lilkova
Saved on
Feb 16, 2024
Previous Change: Difference between versions 12 and 13
Next Change: Difference between versions 14 and 15
View Page History
This line was added.
This line was removed.
Formatting was changed.
Fancy Bullets
type
circle
Live & Referenced (through USD) geometry
Live volumes
Instancing & Variants
Cryptomatte (through Husk)
AOVs
V-Ray Lights, Light Mixer, Light Linker
V-Ray Materials
V-Ray Textures
V-Ray Displacement
V-Ray Subdivision
V-Ray Proxy
V-Ray Environment Fog
V-Ray Toon Effect
V-Ray Physical Camera (with Depth of Field & Motion Blur)
V-Ray Object Properties (through Render Geometry Settings LOP)
V-Ray Hair Properties (through Render Geometry Settings LOP)
V-Ray Matte Surfaces (through Render Geometry Settings LOP)
V-Ray Render Settings (through Render Settings LOP)
V-Ray Production/Final rendering (through USD Render ROP LOP)
V-Ray Batch rendering (through Husk)
Native Houdini volumes
Solaris Render Region tool
MtlX shaders
(without volumetric shading, layered brdf shaders, and lights)
V-Ray Profiler
Hydra Ocean
Feather Procedurals
Resumable rendering
V-Ray Clipper (through the Render Geometry Settings LOP)
OSL texture and material
COP (/img) nodes
Trace sets
Temporary Limitations
Fancy Bullets
type
circle
V-Ray Aerial Perspective
is not implemented.V-Ray Clipper
is not implemented.
V-Ray Fur is not implemented
V-Ray Plane is not implemented
V-Ray VRScene import is not available due to a Solaris limitation
