These features are supported by V-Ray and V-Ray GPU in Maya. Note that IPR rendering uses Brute Force GI by default but Light Cache is also available.
Limitations
IPR Rendering does not support the particle instancer.
Supported Features
width45%
Geometry
Feature
V-Ray
V-Ray GPU
Triangle meshes
(tick)
(tick)
V-Ray Proxy
(tick)
(tick)
Alembic via proxy
(tick)
(tick)
NURBS
(tick)
(error)
Subdivisions
Anchor
1.1
1.1
(tick)
(tick)
Displacement 1
(tick)
(tick)
V-Ray Fur
(tick)
(tick)
Maya Hair
(tick)
(tick)
XGen
(tick)
(tick)
Infinite plane
(tick)
(tick)
Particles
(tick)
(All types except tube, cloud,
and numeric. Type "blobby
surface" renders as spheres.)
PARTIAL
(only spheres)
MASH
(tick)
(tick)
VRayClipper
(tick)
(tick)
VRayDecal
(tick)
(tick) 14
V-Ray Enmesh(tick)(tick)
VRayPerfectSphere(tick)
(tick)
(CUDA only)
ChaosScatter(tick)(tick)
back to top
Lights
Feature
Anchor
8.8
8.8
V-Ray
V-Ray GPU
Textured lights 8
(tick)
(tick)
V-Ray Lights
(tick)
(tick)
Standard Lights
(tick)
(tick)
Photometric Lights
(tick)
(tick)
Image-based lighting
(tick)
(tick)
Light and shadow linking
(tick)
(tick)
VRaySun's Clouds 16(tick)(tick)
back to top
Materials
Feature
V-Ray
V-Ray GPU
VRayAlSurface
(tick)
(tick)
VRayBlendMtl
(tick)
(tick)
VRayCarPaint
(tick)
(tick)
VRayCarPaint2
(tick)
(tick)
VRayLightMtl
(tick)
PARTIAL
(without Opacity)
VRayMtl
(tick)
PARTIAL
(without
Diffuse Roughness)
VRay2SidedMtl
Anchor
13.1.13.1
13.1.13.1
(tick)
PARTIAL
(without Multiply By Front diffuse)
VRayMtlWrapper
Anchor
2.2
2.2
(tick)
(tick) 12.1
VRayFastSSS2 2
(tick)
PARTIAL
(without raytraced (solid) and raytraced (refractive))
VRayFlakesMtl
(tick)
(tick)
VRayFlakes2Mtl
(tick)
(tick)
VRayHairNextMtl
(tick)
(tick)
VRayGLSLMtl
(tick)
PARTIAL 9
VRayHairMtl
(tick)
(tick)
VRayBumpMtl
(tick)
(tick)
VRayVRmatMtl
(tick)
(tick)
VRayOSLMtl
(tick)
(error)
VRayScannedMtl
(tick)
(tick)
VRayStochasticFlakesMtl
(tick)
(tick)
VRaySwitchMtl
(tick)
(tick)
VRayToonMtl
(tick)
(error)
VRayMtlRender Stats
(tick)
(tick)
VRay Mesh Material
(tick)
(tick)
VRayPointParticleMtl
(tick)
(error)
VRayMaterialX
(tick)
(tick)
Maya Ramp Shader
(tick)
(error)
back to top
Textures
Feature
V-Ray
V-Ray GPU
Bitmap
(tick)
(tick)
Checker
(tick)
(tick)
Anchor
7.7
7.7
Bulge
(tick)
Anchor
7.1.7.1
7.1.7.1
(tick) 7
Cloth
(tick)
(tick) 7.1
Fractal
(tick)
(tick)
Anchor
7.2.7.2
7.2.7.2
Grid
(tick)
(tick) 7.2
Mountain
(tick)
Anchor
7.3.7.3
7.3.7.3
(tick)
Wood
(tick)
(tick)7.3
Sampler Info
(tick)
PARTIAL
Ramp
(tick)
(tick)
Substance
(tick)
(error)
Noise
(tick)
(tick)
Anchor
7.4.7.4
7.4.7.4
Granite
(tick)
Anchor
7.5.7.5
7.5.7.5
(tick) 7.4
Leather
(tick)
Anchor
5.5
5.5
(tick) 7.5
LookDevKit nodes
(tick)
(tick) 5
VRayFresnel
(tick)
(tick)
Vertex Color
(tick)
(tick)
VRaySky
(tick)
(tick)
VRayDirt
(tick)
PARTIAL
VRayFalloff
(tick)
(tick)
VRayTemperature
(tick)
(tick)
VRayEdges
(tick)
(tick)
VRayDistanceTex
(tick)
Anchor
9.9
9.9
(tick)
VRayGLSL
(tick)
PARTIAL 9
VRayPTex
(tick)
(error)
VRayHairSampler
(tick)
(tick)
VRayFurSampler
(tick)
(tick)
VRaySoftBox
(tick)
(tick)
VRayOSLTex
(tick)
(tick)
VRayParticleTex
(tick)
(error)
VRayRaySwitch
(tick)
(error)
VRayTriplanarTex
(tick)
(tick)
VRayUserColor
(tick)
(tick)
(no alpha attribute)
VRayUserScalar
(tick)
(tick)
VRayCurvature
(tick)
(tick)
VRayLayeredTex
(tick)
(tick)
VRayInverseExposure
(tick)
(tick)
VRayUVWRandomizer
(tick)
(tick)
VRayMultiSubTex
(tick)
(tick)
back to top
Maya Utility Nodes
Feature
V-Ray
V-Ray GPU
contrast
(tick)
(error)
clamp
(tick)
(tick)
gammaCorrect
(tick)
(tick)
luminance
(tick)
(tick)
ramp [Texture]
(tick)
(tick)
remapColor
(tick)
(tick)
remapHsv
(tick)
(tick)
remapValue
(tick)
(tick)
blendColors
(tick)
(tick)
samplerInfo
(tick)
PARTIAL
(see table below for more information)
multiplyDivide
(tick)
PARTIAL
plusMinusAverage
(tick)
PARTIAL
reverse
(tick)
(tick)
surfaceLuminance
(tick)
(error)
hsvToRgb
(tick)
(tick)
choice
(tick)
(error)
back to top
Anchor
samplerInfo
samplerInfo
samplerInfo
Feature
V-Ray
V-Ray GPU
Ray Direction
(tick)
(error)
Normal Camera
(tick)
(tick)
Pixel Center
(tick)
(error)
Point Camera
(tick)
(tick)
Point Obj
(tick)
(error)
Point World
(tick)
(tick)
Tangent UCamera
(tick)
(error)
Tangent VCamera
(tick)
(error)
UV Coord
(tick)
(tick)
back to top
Anchor
multiplyDivide
multiplyDivide
multiplyDivide
Feature
V-Ray
V-Ray GPU
No operation
(tick)
(error)
Multiply
(tick)
(tick)
Divide
(tick)
(tick)
Power
(tick)
(tick)
back to top
Anchor
plusMinus
plusMinus
plusMinusAverage
Feature
V-Ray
V-Ray GPU
Input 1D
(tick)
(error)
Input 2D
(tick)
(error)
Input 3D
(tick)
(tick)
back to top
Environment
Feature
V-Ray
V-Ray GPU
Spherical Mapping
(tick)
(tick)
Mirror ball mapping
(tick)
(tick)
Angular mapping
(tick)
(tick)
Toon shading
(tick)
(error)
VRaySimpleFog
(tick)
(error)
VRayScatterFog
(tick)
(error)
VRayEnvironmentFog
(tick)
(tick) 13
VRayAerialPerspective
(tick)
(tick)
back to top
width10%
width45%
Global Illumination
FeatureV-RayV-Ray GPU
Brute Force
Anchor
3.3
3.3
(tick)
(tick)
Light Cache 3
(tick)
(tick)
Caustics New Map(tick)(minus)
Caustics Progressive(tick)
(Progressive Image Sampler)
(minus)
back to top
Cameras
Anchor
16.16
16.16
Feature
Anchor
5.5
5.5
V-RayV-Ray GPU
Motion blur (transformation and deformation)
(tick)
(tick)
Camera motion blur
(tick)
(tick)
Camera DoF
(tick)
(tick)
VRayPhysicalCamera
(tick)
(tick)
Stereoscopic
(tick)
(tick)
Dome Camera
(tick)
Distortion for Physical Camera
PARTIAL15
Camera shader texture(tick)(tick)17
back to top
Render Elements
Preset: Back to Beauty(tick)(tick)
Atmospheric Effects(tick)(tick)
Background
(tick)
(tick)
Bump Normals
(tick)
(tick)
Caustics
(tick)
(Production mode)
(error)
Coat Specular(tick)(tick)
Coat Filter(tick)(error)
Coat Glossiness(tick)(error)
Coat Reflection(tick)(tick)
Coverage
(tick)
Anchor
6.6
6.6
 (error)
Anchor
11.11
11.11
Cryptomatte
(tick)6
(tick)
Custom Color(tick)(error)
DR Bucket(tick)
(Bucket sampling
(tick)
Denoiser
(tick)
(tick)
Diffuse
(tick)
(tick)
Extra Tex
(tick)
(tick)
GI
(tick)
(tick)
LightMix(tick)
(tick)
Anchor
12.12
12.12
Light Select
(tick)
Lighting
(tick)
(tick)
Lightning Analysis(tick)
(error)
Material ID(tick)(tick)
Material Select(tick)(error)
Matte Shadow(tick)(error)
Multi Matte(tick)(tick)
Multi Matte ID(tick)(error)
Noise Level(tick)(tick)
Normals(tick)(tick)
Object ID(tick)(tick)
Object Select(tick)
Anchor
18.18
18.18
(error)
Raw Coat Filter(tick)(error)
Raw Coat Reflection(tick)(error)
Raw Diffuse Filter(tick)(error)
Raw GI(tick)(tick)18
Raw Light(tick)(tick)18
Raw Reflection(tick)(tick)18
Raw Reflection Filter(tick)(error)
Raw Refraction(tick)(tick)18
Raw Refraction Filter(tick)(error)
Raw Shadow(tick)(tick)18
Raw Sheen Filter(tick)(error)
Raw Sheen Reflection(tick)(error)
Raw Total Light(tick)(tick)18
Reflect IOR(tick)(error)
Reflection Filter(tick)(tick)
Reflection Glossiness(tick)(error)
Reflection Highlight Glossiness(tick)(error)
Refraction Filter(tick)(tick)
Refraction glossiness(tick)(error)
Render ID(tick)(tick)
Render Time(tick)(tick)
SSS(tick)(tick)
Sample Rate(tick)(tick)
Sampler Info(tick)(tick)
Self Illumination(tick)(tick)
Shadow(tick)(tick)
Sheen Specular(tick)(tick)
Sheen Glossiness(tick)(error)
Sheen Reflection(tick)(tick)
Toon(tick)(error)
Toon lighting(tick)(error)
Toon specular(tick)(error)
Unclamped Color(tick)(tick)
Velocity(tick)(tick)
VRScans Paint Mask
(tick)(error)
VRScans Zone Mask(tick)(error)
Z Depth(tick)(tick)
back to top
Overrides - Camera
Override FOV(tick)(tick)
Depth of Field(tick)(tick)
Motion blur(tick)(tick)
back to top
Overrides - Geometry
Displacement(tick)(tick)
Subdivision(tick)(tick)
Viewport subdivision(tick)(tick)
Hair/PaintFX/Fur(tick)(tick)
Proxy Objects(tick)(tick)
Particles(tick)(tick)
Plugin Geometry(tick)(tick)
Hidden geometry(tick)
(Production mode)
(error)
back to top
Overrides - Lighting
Lights(tick)(tick)
Hidden lights(tick)(tick)
Shadows(tick)(error)
Ignore shadow and light linking(tick)(tick)
Disable self-illumination(tick)(error)
Probabilistic lights(tick)(tick)
back to top
Overrides - Materials
Reflection / Refraction(tick)(error)
Glossy effects(tick)(error)
SSS
Anchor
4.4
4.4
(tick)(error)
Global max depth 4(tick)(error)
Max Transparency levels(tick)(error)
Transparency cutoff(tick)(error)
Allow negative shader colors(tick)(error)
back to top
Overrides - Textures
Maps(tick)(error)
Filter maps(tick)(error)
Uninverted normal bump(tick)(error)
back to top
Overrides - Rendering
Don't render final image(tick)
(Production mode)
(error)
Secondary ray bias(tick)(tick)
Max ray intensity(tick)(tick)
back to top
Overrides - Environment
Environment override(tick)(tick)
back to top
Overrides - Volumetrics
Environment volume(tick)
(tick)
Probabilistic volumetrics(tick)(error)
back to top
Other
VRayLensEffects (VFB)
(tick)
(tick)
Anchor
10.10
10.10
VRayVolumeGrid
(tick)
PARTIAL 10
Antialiasing
(tick)
(tick)
Color Mapping
(tick)
(tick)
VFB
(tick)
(tick)
Render Mask
(tick)
(tick)
VRayMetaballs
(tick)
(error)
UDIM/UVtile texture tags
(tick)
(tick)
Anisotropy
(tick)
(tick)
UVWProjections
(tick)
(tick)
(perspective & planar modes)
Bitmap/Geometry cache
(tick)
(tick)
VRay Renderable Curves set
(tick)
(tick)
V-Ray custom user attributes
(tick)
(tick)
(flat colors)
Matte objects
Anchor
13.2.13.2
13.2.13.2
(tick)
(tick) 12.2
V-Ray Profiler
Anchor
19
19
(tick)PARTIAL19
back to top
Footnotes
1 – Displacement results between V-Ray and V-Ray GPU may differ slightly because of Pre-tessellation and Cache Normal settings.
