After installation, you need to activate Corona. The process differs depending on your version.
width70%75%
Panel
borderColororange
borderStylesolid
Fancy Bullets
typecircle
  • For Corona 8 or newer, you go through a general Chaos License Server Activation. See this article for the whole process.
  • For Corona 7 or older, you go through the legacy Corona License Activation. See this article for the whole process.
width30%25%
