UI Text Box | ||
Color correction layers like Exposure and White Balance can be applied to a single layer instead of the entire composite. You can do that by selecting a layer and then adding a new correction or by dragging the correction layer to another layer until an arrow icon appears. |
The Stamp, Display Correction, Lens Effects, Sharpen/Blur, Denoiser, and Source layers are listed in the Layers panel by default to any rendered image. Their order cannot be changed.
UI Text Box | ||
If you want to keep the layers that come with the Maya scene, turn the Auto Load Layers option off from VFB > Options Settings > History tab. If you want to load layers from an external image, enable the Auto Load Layers option and check how you save those images. |
