This page contains information about the V-Ray Rock Texture.
width55%
The V-Ray Rock Texture generates a procedural rock pattern using two colors or texture maps.
UI Path: ||mat Network|| > V-Ray > Texture: Procedural > V-Ray Rock
width5%
width40%
width55%
Color 1 – Controls the first of the two colors used by the V-Ray Rock procedural.
Color 2 – Controls the second of the two colors used by the V-Ray Rock procedural.
Mix Ratio – Controls the mix between Color 1 and Color 2. For more details, please see the Mix Ratio example below.
Grain Size – Controls the size of the fine grain features. For more details, please see the Grain Size example below.
Diffusion – Lower values make the resulting texture sharper, while higher values blur the texture details moreFor more details, please see the Diffusion example below.
Wrap – Enables wrapping for the texture.
width5%
width40%
Multiexcerpt include
MultiExcerptNameTweaksHoudini
PageWithExcerptV-Ray Bercon Distortion
MultiExcerptNameMappingHoudini
Anchor
exampleGrainSize
exampleGrainSize
Example: Grain Size
width25%
width50%
Image slider
Panel
borderStylenone
Grain Size: 0.01
Panel
borderStylenone
Grain Size: 0.05
Panel
borderStylenone
Grain Size: 0.1
width30%
width25%
Anchor
exampleDiffusion
exampleDiffusion
Anchor
exampleMixRatio
exampleMixRatio
width5%
width45%
Image slider
Example: Diffusion
Panel
borderStylenone
Diffusion: 0.1
Panel
borderStylenone
Diffusion: 1.0
Panel
borderStylenone
Diffusion: 2.0
width45%
Example: Mix Ratio
Image slider
Panel
borderStylenone
Mix Ratio: 0.1
Panel
borderStylenone
Mix Ratio: 0.5
Panel
borderStylenone
Mix Ratio: 0.9
width5%
Fancy Bullets
typecircle
  • If V-Ray Rock textures are combined, diffusion can be used to provide a large detail coloring in one instance of V-Ray Rock texture and finer details provided with another. If black and white values are used then this could be a great way to generate realistic bump maps.
